On a TV that got stuck at the logo, I opened to check the voltages from the PSU to the main.
Instead of putting the black probe to the ground I put the red one and just didn't bother to get negative voltages. At some point as I was checking through the pins the backlights went off for a sec and then on again. I screwed the TV back together to check it thoroughly another time, plugged it in one more time and the picture was gone.. only backlights.
Can it be that using the probes inverted when measuing voltages with the MM can damage the panel or in general el.components?
I didn't short any pins with the black probe checking the pins for sure.
