MacBook Pro USB slots unrecognizable
    Re: MacBook Pro USB slots unrecognizable
    working USB voltages will help if a USB mouse is connected to it.
    the most probable suspects are L4600, D4600, L4610, D4610, U4650. It would be good if you test them.
      Here are the good voltages from the board with working USB ports:
      With USB mouse connected:
      4. 0.0mV
      3. 7.1mV without mouse moving
      2. 3.075V
      1. 5.04V
      4. 0.0mV
      3. 13.1mV without mouse moving
      2. 3.060V
      1. 5.04V
      Without USB mouse connected:
      4. 0.0mV
      3. 0.3mV
      2. 0.3mV
      1. 5.04V
      4. 0.0mV
      3. 0.3mV
      2. 0.3mV
      1. 5.04V
        Here are the bad voltages from the board I am fixing:
        4. 0.0mV
        3. 1.0mV
        2. 4.88V
        1. 5.00V (This voltage drops to 4.95V with USB hard drive connected)
        4. 0.0mV
        3. 2.9mV
        2. 3.184V
        4. 0.0mV
        3. 0.9mV
        2. 40.0mV was around here and kept slowy rising
        1. 5.00V
        4. 0.1mV
        3. 70.0mV was around here and kept slowy rising but kept going up and down about 0.5mV and still rising
        2. 1.1mV
        1. 5.00V
          these voltages are different from the healthy board's. but they do not say what is wrong. Now test L4600, D4600, L4610, D4610. It will be great if you find a faulty one.
            Hi!
            I think you should check the channel of Loius Rossman. He made many usb port fixies on macbooks. M
              L4600
              1. 1.1mV
              2. 1.1mV
              3. 62.0mV
              4. 1.0mV
              L4610
              1. 1.0mV
              2. 90.5mV
              3. 1.2mV
              4. 1.2mV
              D4600
              1. 0.0mV
              2. 0.5mV
              3. 0.1mV
              4. 0.6mV
              5. 66.0mV
              6. 2.5mV
              D4610
              1. 0.0mV
              2. 2.6mV
              3. 1.4mV
              4. 91.8mV
              5. 0.7mV
              6. 1.3mV
                Originally posted by DjBigman View Post
                Hi!
                Thanks, I found his USB repair video that was done on the same model as mine and it helped me understand the USB circuit a bit better
                  Originally posted by Johndill View Post
                  L4600
                  1. 1.1mV
                  2. 1.1mV
                  3. 62.0mV
                  4. 1.0mV
                  L4610
                  1. 1.0mV
                  2. 90.5mV
                  3. 1.2mV
                  4. 1.2mV
                  D4600
                  1. 0.0mV
                  2. 0.5mV
                  3. 0.1mV
                  4. 0.6mV
                  5. 66.0mV
                  6. 2.5mV
                  D4610
                  1. 0.0mV
                  2. 2.6mV
                  3. 1.4mV
                  4. 91.8mV
                  5. 0.7mV
                  6. 1.3mV
                  The filters L4600 and L4610 don't look right. The same voltage should pass through all pins. The working board has 0.3mV on all pins of L4600 and L4610.
                    measure voltages on L4600 and L4610 while a usb mouse is connected. In the youtube channel of Loius Rossman, there is a video on how to properly test inductors like L4600 and L4610 and what kinds of problem they might have. you should watch it. Because I am not a Macbook specialist, I cannot help much in Macbook repair.
                      His opinion was replace it as a multimeter can't test filters properly, so I'll test again with a USB mouse connected and see what I get.
                        One port randomly started working when I was measuring the voltage of its filter which I think was L4610 pin 4 was 3.0V and 4.88V on pin 3 so replacing both filters (L4600 and L4610) seems like the next step.
                          Success!! My YIHUA 858D arrived yesterday and I've replaced L4600 and L4610 from a dead donor board successfully
                          Both USB ports are now working, thank you Caspian for the tech help once again and DjBigman for referring me to Loius Rossman as his videos were a big help
                          Don't know why the third picture is uploading upside down.
                            Hi, I don't have a donor board to replace L4600. Does anyone know what kind of part this is and where can I purchase this part?
                              L4600 is an EMI filter that is common to use to filter out noise on USB D+/D- lines.
                              We use them in our product designs all the time. The footprints do vary.
                              They are technically not required so you can, for now, remove this 4 pad SMD part and bridge then as straight through. Often you can apply a solder blob in series to allow for the D+ to bridge to the downstream D+ and then D- to D-.
                              Be sure to NOT short D+ to D-.
                              Then you can test again to see if the USB port is working.
                              The part listed in the schematic is from Murata but is very common to source from other vendors.
                              Murata DLP11S EMI filter:
                              DLP11SA900HL2L (believe this one should work fine)
                              https://www.arrow.com/en/products/dl...-manufacturing
                              hope this helps.
                                hope this helps.
                                Many thanks for this tip, it helped to identify that the both L4600 and L4610 are broken.
                                  @damfunk, excellent!! Very glad to hear that it helped.
