Cyberpower PR1500 won't charge battery
    Re: Cyberpower PR1500 won't charge battery
    That is charging circuit section.
    They are Gate (for Q29) resistors.
    R103 is 47 Ohms
    R104 is 47K Ohms
    They burnt up due to the MOSFET Q29 and more likely the SMPS IC U7 is also damaged when the MOSFET failed.
      UPDATE: The second PR2200, which I bought when the first one died, died a couple of weeks ago. [Same symptoms; batteries discharging (without my noticing); power failure; after power back, unit dead.]
      So, this time, I changed only C40 and charged the batteries on the car battery charger.
      Started it up. No load. Charge indicator on start-up was three green lights out of four.
      After a couple of hours, the fourth charge light came on. Charging circuit seems to be working again. [Thanks, budm.]
      Self-test says it's OK. Will try it with some load...
      Might as well wait until the next power failure to put it back into use. [It's for a computer that I never shut down.]
      And, it's time to take another look at the other PR2200.
        I have the same battery charge problem on my PR2200E on 230VAC 50Hz.
        I changed the C40 capacitor and it works
        Thank you very much
          Thank you very much
          Glad to hear, you may as well replace other caps in the cold side also.
            Yes, I will replace all others caps, I changed the C40 with a cap picked up in a old DVB TV receiver for testing.
            All charge caps ar now ordered
            Regards
            DB
              I have a CyberPower 1350 AVR that failed similarly. I had to replace the VIP22A. Then the unit began functioning, but it is not charging the batteries. I have been looking for schematics without success. The layout of the board is quite different from the 1500 unit. Any suggestions appreciated. I have not located the corresponding Cap to the C40.
              Thanks,
              Roy
                Thanks,
                Roy
                How uploading good clear pictures?
                What is the charging Voltage is showing right now? How old are the batteries?
                  Hi Budm,
                  I am currently charging the batteries, but when they were installed the voltage of the two in series was 24 volts or below. On charge it should get to be 28 volts or better. The original batteries were very bad and only produced 6 volts each after a charge. The user had no idea he needed to change them. I regularly change the batteries on my UPSes at the office every two years, so I took two recently removed still functional charged batteries for testing purposes. I am waiting for my pictures to up load to Google so I can post them.
                    Here are some photos. Under the angled sink is a 15 volt regulator. There is a
                    SM6002N to the left of the switcher sinks, for control I suppose.
                      The whole thing is pretty dense. It is hard to get good pictures.
                        After studying the 1500 schematics and some other examples of charging circuits online I looked at the board again. Early on in the charging circuit there is a choke. Connected to the input side is a 2 amp fuse which is open. The unit itself was probably damaged in a lightening strike so this makes sense. The VIP22A that I replaced is just before a transformer, also an induction target.
                        Now to get the fuse. It is an axial presentation which will be harder for me to get here. I will find a way around this minor problem. I am grateful for this forum. Although it did not present me the answers, it has helped to understand better what I need to be thinking. Understanding is helpful
                        I will continue posting as I progress.
                        Roy
                          After replacement of the fuse, still no charging. There is an optocoupler across the charging transformer bounder that was not activating. Checking the sensing circuit, I noticed a 5W 33 ohm resistor with a bad soldier joint which I repaired.
                          It now does appear to be charging. The charging voltage across the two batteries in series is 25.8 volts and gradually rising, which looks good. I will post again when I am sure.
                            I'm having a similar issue with a Cyberpower CP1500AVRLCD and a lot of fruitless Googling finally led me to this thread/forum.
                            The unit itself has worked flawlessly for the last 9-10 years and I've replaced the batteries every ~3 years or so. A few weeks ago, I once again replaced the batteries and they initially showed as 7%. They charged up to ~60% and then stopped (software shows 60% and charging for over a day). Thinking the batteries were defective, I requested a replacement and put back in the old batteries even though they were very weak.
                            However, the old batteries showed similar behavior. I took them out and charged them to full on a regular charger and put them back in only to see them drop from ~95% back to 60% all while constantly 'charging'.
                            I've bought a replacement UPS but am going to try and get the old one working again.
                            From what I've read in this thread, it looks like the charging voltage isn't where it is supposed to be. I tried to get a reading from the leads from the UPS, but the unit will not turn on with the batteries disconnected. If I connect the batteries and start the unit, I get the same voltage as I did when testing the batteries themselves unloaded (24.8V at moment).
                            However, once it does the self-test, the capacity drops from 60 down to 3% and it starts charging up slowly again (and will stop at ~60% again).
                            I have some free time on Monday so I plan to start taking it apart and seeing what I can find. In the meantime, I'm hoping for some advice/comments on whether my presumptions are correct and if someone might have the schematic diagram for this particular unit.
                            If someone can suggest a way to measure the true output of the charging circuit, that would be great, too.
                            Thanks in advance.
                              Hmm, the charging circuit is on the minute you plug the power cord into the AC outlet.
                              From user manual:
                              https://cdn.badcaps-static.com/pdfs/...9153daf881.pdf
                              HARDWARE INSTALLATION GUIDE
                              1. Battery charge loss may occur during shipping and storage. For the first time the UPS is used, it's strongly
                              recommended to charge batteries for at least eight hours is recommended to ensure that the batteries' maximum
                              charge capacity. To recharge the batteries, simply make the UPS plugs into an AC outlet.
                              I have lots of Cyber power UPS here at work.
                                From user manual:
                                Thanks, I didn't realize that. I admit that, when it didn't turn on, I didn't bother measuring.
                                I had left the unit charging overnight and it was up to 49%. I turned it off and measured the leads from the UPS and it was 27.8V. I measured the batteries and they were at 24.2V.
                                However, when I reconnected and turned the unit back on, the capacity dropped to 3%.
                                  So right all the batteries you have for testing are 3 years old or more? It sounds to me like the batteries are not holding up the charge.
                                  BTW, that 27.8V readings is with the batteries connected, right?
                                  You can also connect DC Amp meter (connected in series with the battery or use DC A clamp on meter) to see how much charging current is being fed to the batteries.
                                    The old batteries were 3 years old, but the new one was purchased just a few weeks ago. When I put them in, the unit reported them as 7%, however, so perhaps the new ones are bad as well. Am waiting for the replacement ones to arrive to test.
                                    The 27.8V was with the batteries disconnected. Just checked the charging current and it was 13.5mA (which seems really low). The unit is reporting 60% again and the batteries show 24.4V which seems to correspond to the 60% based on a state-of-charge chart.
                                    One side note, if it matters. The new batteries are 7AH while the old ones were 9AH. I read that the only difference was a reduced run-time, but don't know for sure.
                                      @13.5mA means it is not being charged at all, it may mean that the charging is not working at this point, it can put out 27.8V with no load but not with load (Batteries) connected.
                                      9Ah will have longer run time than the lower AH.
                                      You can try connecting 40W lamp (it will have cold resistance about 24 Ohms, hot resistance of 360 Ohms) in place of batteries to draw about 1A and see if the output Voltage of the charger will be around 27V or not.
                                        Re: Cyberpower 1350AVR won't charge battery
                                        Hi Guys,
                                        Although I don't have schematics for my CyberPower 1350AVR I have found a diagram that approximates the circuit I am working on. I need to understand the VIP22A which really handles the charging. Like the 1500 units my batteries are not charging either. I have replaced the VIP22A which was burned and a burned out fuse but still no joy.
                                        There is a link to the document with the diagram that has been helpful to me.
                                        https://cdn.badcaps-static.com/pdfs/...4d8ae765c7.pdf
                                        On operations 4, 4.1 of that document the corresponding diode to my unit is D3. It is shorted. It is D23 on my attached pictures. I have attached some photos of the diode too. It is fed by a 22uf 50V cap that I have ordered.
                                        This diode is a really tiny glass case unit. I am going to try to get a powerful magnifying glass to augment my shop one which is indeed powerful. So my problem is that I can't read the part number. I am studying the 1500 schematics for an idea.
                                        Many of you are much much better techs than I will ever be. Your suggestions are desired and welcomed. What do you think it might be?
                                        Thanks so much,
                                        Roy
                                          Can we see the whole top and trace side of the board?
                                          I cannot tell using your pictures in your post 69 to figure out the circuit where D23 is actually used in the circuit.
