Re: gateway desktop no post
First, lets clear up some questions about the Bestec power supply. The last photo you posted showed the output side of the power supply. There are two semiconductor devices screwed to the heat sink, both are diodes. I also see some crud on the top of one of the capacitors. Check this closely as it is probably a bad capacitor leaking.
What I am looking for is to see if there are two transistors on the other heat sink - on the other side of the pc board. See if you can get pictures of what is on the other heat sink.
