Hello friends, I need help please, I have arrived at latitude 7280, with a very slow start, it takes more than 1 minute for the dell logo to appear, check the bios chip (uc5) and I was intervened then remove the bin and clean the region, but it does not give an image with the region it cleans me, I tried 2 files from other computers that I have but none gives an image Does anyone have any ideas? Will I have to change the firmware of the other chip (ut6)? I leave my original file if someone can review for me.
Latitude 7280 bios
Re: Latitude 7280 very slow boot
try..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Originally posted by aldopc View PostHello Smdflea, the service tag is G901QN2, the team came to me like this with the bios that I initially uploaded ...
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Ok, friends I appreciate your help I will summarize a little I have removed and installed the bios chip about 25 times, finally the problem was in the bios chip gd25q128, I replaced it with a windbond windbond 25q128, and the problem was solved, with the smdflea file turned on and asked for the servicetag when turning on, but it did not start from the bootmanager I did everything in the boot configurations I could even install the so, but it does not start, then I tried the second Plague file, this perfect fire and took the start the bootmanager right away only with the service tag of another computer, the same with the lapfix file, then I removed the file and with the serial number editor I changed the service tag for the one that is on the computer cover and it worked wonderfully, I sincerely thank you I was going crazy to all of you ...
Very hard to fix it. I have the same problem. You cannot mixed the bioses in 7280 models. You need same dump as your original board. Check your board dell part number and need exact the same part numbered dump to fix it. I have solved mine but was not as easy fix. If you have the correct dump you need to clean ME with the correct CSME 11 version.
You cannot mixed the xhip content also, I mean you need dump from an identical chip model also. There are extremely rare on the net dumps from latitude models. Lot of different revisions...
Re: DELL Latitude 7280 bios request
Post your original corrupt bios file here.
Become a Badcaps supporter
Thanks to all supporters.
Re: Dell latitude 7280 clear
Originally posted by pronto View Posthi every one can you clean me this bin bios of dell latitude 7280. thanks for helpAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
>>>>> click on this link to donate via PayPal. <<<<<
Re: la-f311p rev 3.0 need bios dump
Originally posted by bilen View Postlatitude 7280
service tag : F0BZ4H2
orginal dump no screen
try clean MEAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
