Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Old 11-25-2017, 08:10 AM   #261
Khron
City & State: Valkeakoski
My Country: Finland
Line Voltage: 230VAC 50Hz
Default Re: Repairing Alesis M1 Active mk2 Monitor Speakers
Originally Posted by momaka View Post
I think what Micwest meant by his comment above is that he touched his positive multimeter probe to the MOSFET's Gate and the negative probe to Source. When you do this for a N-channel FET out of circuit, this will make the MOSFET turned "ON", so you will get a low resistance / diode reading between Source and Drain. If you de-energize the Gate, you should get open-circuit or a diode reading between Source and Drain, depending on the probe orientation, as you said. So his MOSFET may be okay, if I understood his testing correctly.
That's what i had tried to confirm mitigate by having said:
Originally Posted by Khron View Post
Touch the gate and source of Q1 together (to discharge the gate) and measure again. If there's any charge left on the gate, that will keep the MOSFET open, and the drain-to-source voltage drop will be lower.
Khron is offline   Reply With Quote
Old 11-26-2017, 09:08 AM   #262
audioboy
City & State: Shetland
My Country: United Kingdom
Hi guys,
Hope someone can lend me a hand here! My mk2s blew a few months back and I've finally gotten round to opening them up. Bare in mind I'm a complete novice when it comes to electronics.
I can see a trace that's burned off so that's an obvious fix but I'm stumped as to what else may be wrong. I've tested the c8 and c35 caps and they seem fine to me so I started testing other components in the hope that I'd stumble across the fault. This is probably a silly way to go about it but I'm not sure what else to do. Anyway, I took off R3 and R4 to test them and found they measured 38k instead of the 47k that the service manual declares them to be. Excellent! Or so I thought. The colour code (orange, grey orange, gold from what I can see) tells me that it's a 38k resistor.
So then I thought I'd pull out another resistor to see if I could make sense of that measurement. I pulled out R27 and tested that. Service manual says it should be 100ohm but the colour rings (red, black, gold, gold) tell me it's a 2ohm resistor with a tolerance of 5% and it's reading at 2.4ohm which is outside of its tolerance.
I'm so confused. Should I just ignore the service manual altogether? Is R27 bad? Help... please?
audioboy is offline   Reply With Quote
Old 11-26-2017, 01:51 PM   #263
Khron
My Country: Finland
1) Photos
2) Tested C8 / C35 how, exactly? And "they seem fine" to you, based on what?
3) What colour code / resistance can you measure on R28? They should be the same (at least in theory).
Old 11-27-2017, 12:29 PM   #264
audioboy
Thank you for replying so quickly Khron, I appreciate it.
1) I've attached some photos, hope it works, not used this forum before. There was a load of gunk there that I cleaned out (didn't realise how much I'd scratched the board until I took the photo... *facepalm*).
2) Sorry, was way too vague there wasn't I. I tested them using an ESR meter.
C8: ESR=0.31ohm, Vloss=2.0% and 342.3uF
C35: ESR=6.8hom, Vloss1.2% and 1081nF
Forgot to say that the C8 cap is 330uF 35v but again the service manual says it should be a 220uF 35v although from what I've read it's ok to have a higher capacitance... ?
3) Colour code on R28 is the same as R27 (red, black, gold, gold) and also measures 2.4ohm
Looks like that whole area around D5 has overheated. C8 has some brown stuff caked on to the bottom as you can see in the photo. D5 was covered with the same or similar brown substance what I thought at the time was burned adhesive but doesn't make sense why D5 would be covered in adhesive in the first place. Measured D5 with a multimeter and got 0.62v so I assume it doesn't need replacing even after being covered with that crap?
Wondering if I should remove the burned adhesive on the board just to the right of R18? I read somewhere that it's conductive once browned but don't know how much truth there is to that. Got some conductive paste to repair the broken trace under R18. Do you think maybe the problem is just that broken trace?
Also, after taking out D5 I noticed that the holes for D5 and R5 are pretty close and looks like they'd join when I replace D5. I didn't notice this before removing D5 so I'm wondering if it's my rubbish soldering skills but then looking at the diagram in the photo it looks like they should connect perhaps? Sorry, so many questions and a complete electronics noob... but I'm enjoying it, so far
Old 11-28-2017, 06:29 AM   #265
Khron
My Country: Finland
As a rule of thumb, if an electrolytic says "VENT" on it, i don't trust it as far as i can throw it. Only (some of) the crap brands have that written on them; the good ones don't - coincidence?
I'd replace that, if only to save myself potential headaches down the road. And i'd recommend you use the method i did - relocate C8 to replace C14 next to the chip (and away from the heatsink), and add C14 back, on the bottom of the circuit board. It's in parallel with C8, so no worries there.
If the colour code matches the measured resistance, AND they're both the same, i'd call them good. Highly unlikely they'd both deteriorate to the same exact value, wouldn't you say? And their values aren't exactly critical anyway, they're there more for current-limiting purposes.
Why would D5 be covered in that crap? One reason - zero f**ks given during applying of said goop. But if it measures ok, and the legs aren't too corroded (from the goop), i guess D5 should still be ok.
Yes, remove as much of that adhesive as you can, burnt or not. Yes, it does indeed turn dark, brittle and conductive, as well as corrosive, which is, as i'm sure you can imagine, quite unhealthy for copper traces and component legs.
Conductive paste? I wouldn't, sounds messy, and since that's the drain of one of the MOSFETs, that'll be handling "a bit" of power. Just scrape off the soldermask (green transparent varnish) from the trace, and run a wire (or a resistor leg) where the trace should be / used to be.
Well, what good would "one leg in the air" for either R5 or D5 do, hmm? No physical connection = no electrical connection (since this isn't RF black-magic-voodoo stuff), soooo...
PS: Investing a couple quid in some decent solder-wick (aka. desoldering braid) is priceless - works great for cleaning holes like those.
Old 11-30-2017, 11:43 AM   #266
diydidi
City & State: Pretoria
My Country: South Africa
Take note that the Driver IC can be powered from a 15-19V bench supply. Current limit will be a good idea. This is just to troubleshoot and see that the IC oscillates.
diydidi is offline   Reply With Quote
Old 11-30-2017, 09:32 PM   #267
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Also, some multimeters have considerable offset at low resistance measurements. It's not uncommon to see up to 0.2-0.5 Ohms on a decent meter and up to 3 Ohms on a very cheap meter. So always keep that in mind (best way to check is to touch the multimeter leads together and see what resistance it shows on its lowest scale - that's usually your offset for low resistances below 10-30 Ohms.)
I concur.
That tan glue is absolutely horrible. While it doesn't usually go conductive enough to pass considerable amounts of current, it can pass enough current to turn on a transistor or pull a signal low or high - and that alone can destroy your power supply.
And like Khron said, it corrodes traces, so that's another good reason to remove it.
And a stainless steel sewing needle. You may find one or the other easier. Me, I am definitely better with needle (no I don't do drugs, lol) and can't use wick for almost anything except BGA rework. So you may want to try both methods and see which one works easiest for you.
Old 12-08-2017, 11:17 AM   #268
ultramag
City & State: North east
Hey, so I've been looking at one of these for a couple weeks now trying to get it working. When I got it from a friend the fuse had blown, RT1 and R15 had exploded.
I swapped out C6, C7 and C8 as they had domed. It seems to be the newer revision as C8 is on the other side of the heatsink to the service manual I found online.
I swapped RT1 and R15, measured Q1 and found it was shorted. Swapped Q1 and Q2 but as I removed Q1 the trace lifted with it (goes from Q1 drain to Q2 source through a via on the board). Ran a wire where the trace used to be to reconnect that.
Next I checked the diodes on the bridge rectifier, measured continuity both ways on them and some erratic readings so swapped the lot of them.
So maybe in haste, thinking that I'd found the main problem (Q1 shorting seemed to be the cause) I swapped the fuse and tried to power it up. Fuse blew again straight away. Checking Q1 again it is fine, reading about 490 between drain and source, same as Q2. Diodes all seem fine as well.
I have little to no experience with power supplies but it would be nice to get this working again. Does anyone have any ideas on where to look next? I've clean as much of the glue/fixative from the board as possible (or where appropriate).
My friend noted that before the speaker finally blew, it would cut out a the light would flicker if you turned the volume up past 50% on the back.
ultramag is offline   Reply With Quote
Old 12-10-2017, 06:40 AM   #269
markovitch
City & State: almere
My Country: netherlands
https://oscarliang.com/ctt/uploads/2013/10/mosfet.jpg
http://www.savel.org/stuff/20050525g.gif
(Just to avoid confusions between the meanings of "left", "right" etc)
In the diode-check mode, it does matter which probe goes where.
"No reading" would mean something like "OL" or "1 " (depending on how your meter indicates "out of range"); if it shows all zeroes, or "0.00x", then that's a wire / short-circuited - slight difference there, i'm sure you'll agree.
thanks for the clarifying images, Q2 and Q1 give ma about a diode drop when measuring source to drain. Q1 does the same for gate to drain. Q2 gives no reading on gate to drain (reads 1).
Is the gate to drain supposed to give a diode drop? Or is Q1 defect (i did replace this one so sounds weird).
EDIT -- i read on and noticed you mentioning
On a good MOSFET, you'd only expect around a diode-drop with the red probe on the source, and the black probe on the drain. So if you're getting 0.57v both ways between the drain and source, that's definitely gone bye-bye
This leads me to thinking Q1 got faulty again, but now to found out what caused this. Any suggestions on that?
markovitch is offline   Reply With Quote
Old 12-14-2017, 03:53 PM   #270
momaka
momaka's Avatar
My Country: U.S.A.
Nope! - Not outside a circuit, anyways. In circuit, there may be a protection diode connected to the Gate, in which case that's what you might be reading across.
But in a MOSFET, the Gate is electrically isolated from both Source and Drain (there is a small capacitance between Gate and Source, but that's it). So outside of a circuit, there shouldn't be any resistance or diode drops at all from the Gate to Drain/Source.
Old 12-31-2017, 11:16 PM   #271
superrushfan
City & State: guelph,ontario
My Country: canada
great discussion. does anyone have a schematic for alesis M1 #9-40-1386-a , i think it is the first version of this marked 10/06/98 94vo type 1. its a little bit different than the schematic on page 2. my symptoms are smoke coming out of the tweeter but resistance check shows 3.2 ohms .
superrushfan is offline   Reply With Quote
Old 01-01-2018, 11:06 AM   #272
Khron
My Country: Finland
Amp chip's blown? Sounds like either oscillation, or a considerable DC offset's going on...
Old 01-05-2018, 09:58 AM   #273
markovitch
ok, so this means my replaced Q1 is faulty. What would be the best way to continue? I could replace Q1 again, but my gut tells me it will break again since there is another component faulty which I still need to identify. I have a working speaker that i can cross measure stuff, but I'm just not sure where to begin
Old 01-05-2018, 11:03 AM   #274
momaka
momaka's Avatar
My Country: U.S.A.
Get two more replacement MOSFETs for Q1 first.
Next, check transistors Q3 and Q4 - these are the drivers for Q1. If one of them is bad, they can cause Q1 to get stuck ON and burn out.
Once Q3 and Q4 are verified to be okay, install the first replacement MOSFET for Q1 and use the incandescent series bulb "trick" in place of the fuse to prevent the power supply from blowing up Q1 and any other components again.
Incandescent bulb trick:
https://www.badcaps.net/forum/showpo...4&postcount=70
If the bulb stays fully lit, that means Q1 is stuck ON and may need to replace UC3844 IC. On a normally working SMPS, the incandescent bulb will usually glow briefly for a moment or two and then go OFF or very dim. Of course, that will also depend on your bulb's power rating. I recommend at least 60 Watts. Around 100 Watts is what I use for testing larger SMPSes like the ones for PC and audio gear.
While testing Q3 and Q4, also check D14, Q2, D6, D7, and R18. If these are bad, that could make excessive current flow through Q1 as well.
Old 09-21-2018, 10:25 AM   #275
remondo
City & State: Leeds
My Country: UK
Hi, I have the same issues as everyone else here and I'm in the process of tracking down the issue(s).
Do I need to remove these components from the board to test them?
remondo is offline   Reply With Quote
Old 09-24-2018, 01:49 AM   #276
momaka
momaka's Avatar
My Country: U.S.A.
^ If it's not an issue for you with desoldering those components, then yes, remove and check them anyways. Better to check more parts and find nothing is wrong than to skip a few, then replace the bad one(s) and find out the PSU has the same issues again due to one of the skipped parts also being bad.
Old 11-01-2018, 04:03 PM   #277
ancient geek
City & State: Bristol
My Country: UK
Anyone got any advice on the correct value of L4 of the PSU for this unit. Mine was all burnt, taking out a bunch of other components. The schematic says 25uH, and this is what I have installed, but it gets very hot (>100C) and has fewer turns than the original.
ancient geek is offline   Reply With Quote
Old 11-01-2018, 06:07 PM   #278
Khron
My Country: Finland
Not all inductors are created equal.
I don't suppose you can tell anymore what colour the core might've been, can you? Yellow on the outside, inside and one flat side, and white on the other flat side, perhaps?
Badcaps.net Technical Forums 2003 - 2018
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
