Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 10-09-2019, 06:43 PM   #1
z0oinks
City & State: Mamaroneck, NY
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Knowledge Seeker
Default Backlight and Sound But No Video on Vizio P502UI-B1E
Hey everyone.
Found this TV on the side of the road and the guy who put it there said one day it just stopped turning on.
I took it back and determined that I need to replace the power supply board. Did that and the TV turned on and I could hear audio from my source, but no video and no backlight.
I replaced the EEPROM but that didn't fix anything.
Found https://www.badcaps.net/forum/showpo...&postcount=136 and tried throwing it in the oven.
This fixed the backlight, but still got no picture.
After that, I tried replacing the T-Con board, but that didn't help either.
I've been looking and can't find a main board (XECB0TK004060X) for a decent price. Is there anything else I can try or am I out of luck on this one?
z0oinks is offline   Reply With Quote
Old 10-09-2019, 08:54 PM   #2
z0oinks
My Country: USA
Default Re: Backlight and Sound But No Video on Vizio P502UI-B1E
Looked and I didn't see an edit button....
It's not possible to use a different model number main board is it? I see ones that look the same with slightly different model numbers all over eBay and they're very tempting
Old 10-10-2019, 08:01 AM   #3
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
Your Post Header says Backlight and sound but no video. Then inside the Post you say you hear audio from my source, but no video and no backlight. Are your Backlights working? If YES then your problem lies in a shorted capacitor on the Panel Bd. ( the long boards attached to the LCD Screen). If NO then the LED Driver in the PSU if at fault.
Andrew F. Ali is offline   Reply With Quote
Old 10-10-2019, 08:34 AM   #4
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
Quote:
Have a look at shopjimmy's website and see if they suggest suitable replacement boards
__________________
dick_barton is offline   Reply With Quote
Old 10-10-2019, 09:56 AM   #5
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
So are you getting the backlights or not?
Please upload good clear pictures of the whole back side of the TV showing all the boards.
__________________
budm is offline   Reply With Quote
Old 10-10-2019, 11:04 AM   #6
z0oinks
My Country: USA
Sorry, I was going step by step with what I did and what it fixed.
I didn't have backlight at first, but it came back after throwing it in the oven.
Old 10-10-2019, 11:11 AM   #7
z0oinks
My Country: USA
Just went to go take the pictures and now the backlight isn't turning on again -.-
Pictures are here: https://photos.app.goo.gl/zek6Zbn4gaWfQWJN6
Old 10-10-2019, 07:48 PM   #8
z0oinks
My Country: USA
Another update: Backlight is working again. Didn't change anything besides putting two screws in the main before putting it away for the time being
Old 10-10-2019, 09:24 PM   #9
budm
budm's Avatar
My Country: USA
Since now you do have baklights, so what do you see on the screen if you have the ribbon cables between the T-CON and the LCD panel connected one at a time?
BTW, make sure to put all the screws for the boards back in place.
Old 10-10-2019, 10:42 PM   #10
z0oinks
My Country: USA
I don't know what's going on with the backlight. Sometimes it turns on, other times it doesn't. When it does turn on, it'll stay on indefinitely. But if I turn the TV off and back on, the backlight might not turn on again.
When it does work, this is all I see on the screen regardless of what's plugged into the TCON:
Old 10-11-2019, 09:59 AM   #11
budm
budm's Avatar
My Country: USA
"When it does work, this is all I see on the screen regardless of what's plugged into the TCON:" What do you mean by " regardless of what's plugged into the TCON"????
Old 10-13-2019, 08:45 PM   #12
z0oinks
My Country: USA
When leaving both disconnected, I see what is shown in the picture. When I have the left ribbon cable attached, I see the same thing. If I disconnect the left cable and attach the right, I see the same thing.
Old 10-19-2019, 08:06 AM   #13
z0oinks
My Country: USA
Any ideas?
Old 10-19-2019, 02:50 PM   #14
budm
budm's Avatar
My Country: USA
"When leaving both disconnected, I see what is shown in the picture."
So you are saying you are see grey screen with minus symbol in side the circle when no cables from T-con to LCD panel connected?
I cannot see how it will have ANY image on the screen at all when the panel is not even connected to the T-CON board.
That is the screen shot of your panel, correct?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
