Hi everybody.
I have the monitor Asus VW222U. But it has a problem, of course When it connects to the electricity, without touching any button, it starts changing colors through the spectrum with this message: "ENTER and RIGHT to burn it OFF". The monitor can be turned off, by simple pressing the power button. If turned on again, the colors and the message will appear. In this state remains till touching the power button or pulling out the power cable. So I think the power supply and the inverter is OK. I found somewhere on the net, that when the monitor is off, and is pressed the MENU button and the POWER button at the same time, so the service menu will appear. It don't work at all. Only thing that works is pressing the -(minus) button and the MENU button at the same time, while monitor is flashing colors, to take this state out. Then appear NO SIGNAL, No matter if the monitor is connected to a signal or not. This NO SIGNAL state is there only 2-3 seconds. Then shuts down and the status LED will become orange. After turn ON, the NO SIGNAL status appear again, and again, till pull out the power cable. What this can be? The input?
Sorry for my english...
