It turns on, and the welcome chime plays. The LEDs light up, there is a glow on the screen, but no picture is shown.
There is a ticking sound from a large component on the power board that is a coil of some type (easier to see on the back side). It has a white plastic cover with markings -- see pics.
Power board:
I inspected all electrolytic caps and none looks obviously burnt.
I measured the voltages at connector CNL801 (goes to the LEDs, and according to the chart on the PCB they are LED1 +/- and LED2 +/-, with some pins marked N.C). The voltage fluctuates quite a lot between 2v-7v (I could be off, it changes quite fast)
I measured voltages at connector CNM801 (goes to main board), and based on the chart printed on the PCB, here is what I measured (all voltages wrt ground, i.e., black lead to chassis):
PIN#-Measured Indicated_on_chart
Pin1-12.6 12V
Pin2- N.C
Pin3-12.6 12V
Pin4- 4.83 BL_ON
Pin5-12.6 12V
Pin6-0.47 P_DIM
Pin7- GND
Pin8-0.30 H_SYNC
Pin10- GND
Pin11-5.2 5.3V
Pin12- GND
Pin13-5.2 5.3V
Pin14-5.2 5.3V
Pin15-17.24 Vamp
Pin16-5.21 STBY
Pin17-17.27 Vamp
Pin18-1.53 PS_ON
Main board (HDMI and antenna inputs, ethernet port):
On the main board, there are a lot of test points on the underside, but I don't know what to test for.
T-CON board:
I tested both sides of the T-CON board fuse (white, with gold tips, and it measures 12.46 Volts
I am hoping the buzzing sound of the component on the power board is an indication that the fault is there.
Pics are here: https://photos.app.goo.gl/nfR6V7KXUCJWHT3K9
Any pointers would be really appreciated.
Power board:
Pin1-12.6 12V
Pin2- N.C
Pin3-12.6 12V
Pin4- 4.83 BL_ON
Pin5-12.6 12V
Pin6-0.47 P_DIM
Pin7- GND
Pin8-0.30 H_SYNC
Pin10- GND
Pin11-5.2 5.3V
Pin12- GND
Pin13-5.2 5.3V
Pin14-5.2 5.3V
Pin15-17.24 Vamp
Pin16-5.21 STBY
Pin17-17.27 Vamp
Pin18-1.53 PS_ON
T-CON board:
