I've been finding several LCD/TFT monitors and TVs in dumpster that I've been able to repair. Usually the caps are the root cause for the problems.
In this post I've give my findings about the repair of a Fujitsu SCENICVIEW P24-1W.
I've already repaired two of these monitors and the issue is the same: bad caps.
The monitors that have this problem does not even lights on. Not even the standby.
The fix is done replacing 3 caps.
Check attached images.
Hope this helps someone out there...
Regards
Roberto
Regards
Roberto
