Good day folks. I'd like some advice on this little PSU I'm working on: it's out of a DVD player and I managed to only partly fix it.
When I got it, the transistor was shorted and the fuse was blown. Simple job, I though, I'll just replace the transistor and I'll be back in business. Now because I don't have new replacement parts readily available at this "professional" shop of mine, I dug through some ATX supplies and found one which used STP13007 as the main transistors. I removed one and installed it. The PSU works, but the regulation is rather poor: when unloaded it overshoots, so instead of 12v I get around 14-15. When loaded, the -12v bus drops to around -10v, while the 12v bus goes to a more normal 11v. Same goes for 5v. DVD still didn't power on though: initially, the blue backlight for the display came on but nothing else. Suddenly, as I was measuring the output connector, the PSU started making a faint whistling sound, so I unplugged it immediately. When I plugged it back in, funnily enough the display was showing nonsense on it: dashes and numbers and stuff....true, this could very well be a logic issue and not a PSU issue, however the reason I'm pushing on is because this is a very small and nasty device, yet my STP13007 got rather hot during the short time it was plugged in...
Point is: in the past, I successfully replaced the MJE13005 with MJE13007 or even 13009 and it worked. Could it be an issue here though ? Caps checked fine with my capacitance meter...should I bother to replace the transistor with a 13005 ? That would involve extra digging in the junk box...cheers and thanks.
