Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting & Designing Networks
Thread Tools Display Modes
Old 11-20-2018, 09:41 PM   #1
xfox
City & State: Phily, PA
My Country: USA
I'm a: Knowledge Seeker
Lightbulb Help to identify IC on Linksys EA8500
Hello folks, recently I got wireless router Linksys EA8500, half working.
After visual board inspection I found one bad IC, cannot find anything in google,
maybe someone can help me to identify it. Looks looks it's CPU voltage regulator.
Marked as 208AB 627FL 2019 (UP8) - Voltage around IC - 0v
On other side there is another one 208AB 627FM 2080 (UP12) Voltage 1.05V
Photos in attach
xfox is offline   Reply With Quote
Old 11-20-2018, 10:49 PM   #2
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Default Re: Help to identify IC on Linksys EA8500
208AB looks to be Dual-Buck switching regulator, the 209AB looks to be single Buck switching regulator.
I have no luck finding any info on either one of them.
__________________
budm is offline   Reply With Quote
Old 11-21-2018, 08:28 PM   #3
xfox
My Country: USA
I think I found similar it's SMB208ANT-2019L or SMB208A
Now I have another problem, to find it in stock.
Old 11-27-2018, 09:51 PM   #4
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
You might have another problem if I read this correctly it says that it digitally programmed now is that to mean that it has to be programmed before it installed
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
10 Desk Top Power Supply
1 Dell Mother Board
15 Computer Power Supply
1 Over Head Crane Current Sensing Board
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 11-27-2018, 09:53 PM   #5
sam_sam_sam
My Country: USA
Quote:
DIGITAL INTERFACE/NON-VOLATILE PROGRAMMING 2
The built-in serial digital I C/SMBus compatible port and built-in non-volatile programming bring several benefits to power supply design with the SMB206A/7A/8A. Many external components are eliminated that would otherwise be used to set configuration and parametric values. Additionally, the digital interface allows for quick and easy development and debug without hardware changes. Finally, after the non-volatile power-up configuration, the serial port can be used to re-program the SMB206A/7A/8A by host software after the system is running. For quick programming development and debug use Summit’s prebuilt evaluation kit including a PC- based graphical user interface (GUI).
This is what I am talking about earlier
Old 12-07-2018, 08:06 PM   #6
xfox
My Country: USA
I think router's firmware doing that (IC programming/control), but anyway I was unable to find replacement, it's Qualcomm IC and there is no replacement, so body completely dead.
Old 12-23-2018, 08:11 AM   #7
sam_sam_sam
My Country: USA
You can try this
https://www.hkinventory.com/public/P...Code=&Qty=2562
I have not used them before
When I do an inquiry I ask if they take PayPal if they do not I will not use them
That is just me
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
