ATI Graphic card X1650 set up with 2 displays
    Hi guys i installed an ATI video card X1650 with 2 DVI outputs with 2 monitors and set displays 1 is 19'' the other is 20'' both 16-9 wide screen,i st resolution to 1280-1024, the 19'' monitor has the right screen the other not so much it falls short,check screen pic attach. also it's on Xubuntu 18.04 Distro.Is there anything i can do,thanks
    https://www.ebay.com/itm/ATI-Radeon-...sAAOSw-V1cMrJZ
    Re: ATI Graphic card X1650 set up with 2 displays
    Whats the native resolution of the monitors? does the monitor have an auto adjust button? try pushing it
    You should be able to go into the driver settings and set each displays resolution etc
      Thanks R_J; The max resolution of the Top 20'' Display that gets the right full screen
      1680-1050 and the bottom 19'' screen max resolution 1600-900 this one is the one that cuts on the sides,if i change to any other lower resolution on to screen it does good but the bottom one will not have the right centered screen.
        I'm not familiar with Xubuntu so did you install the driver/software for that card? if you did you should be able to pick each monitor (1) or (2) then change the settings to match each monitor, I'm sure the card can do it, If you swap the monitors around and have the (narrow pic) one as default (1), can you adjust IT(1600x900) for full screen and then how does the (2) monitor look, I know some monitor will look off center etc. untill you run its auto adjustment (my samsung has a button for that, others have it in the menu)
        I have a X1050 card in a windows xp machine
          Again thanks R_J; when i set resolution on 19'' AOC display to 1600-900 i get this see pic attach;
          also $ inxl -f
          frank@frank-ET1331G:~$ inxi -F
          System: Host: frank-ET1331G Kernel: 4.15.0-43-generic x86_64 bits: 64
          Desktop: Xfce 4.12.3 Distro: Ubuntu 18.04.1 LTS
          Machine: Device: desktop System: eMachines product: ET1331G serial: N/A
          Mobo: eMachines model: MCP61PM-GM serial: N/A
          BIOS: AMI v: P01-A2 date: 12/10/2009
          CPU: Dual core AMD Athlon II X2 250u (-MCP-) cache: 2048 KB
          clock speeds: max: 1600 MHz 1: 1400 MHz 2: 800 MHz
          Graphics: Card: Advanced Micro Devices [AMD/ATI] RV535 [Radeon X1650 PRO]
          Display Server: x11 (X.Org 1.19.6 )
          drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
          Resolution: 1280x1024@75.02hz, 1280x1024@75.02hz
          OpenGL: renderer: ATI RV530
          version: 2.1 Mesa 19.0.0-devel (git-8847370 2019-01-05 bionic-oibaf-ppa)
          Audio: Card-1 NVIDIA MCP61 High Def. Audio driver: snd_hda_intel
          Card-2 C-Media driver: USB Audio
          Sound: Advanced Linux Sound Architecture v: k4.15.0-43-generic
          Network: Card: NVIDIA MCP61 Ethernet driver: forcedeth
          IF: enp0s7 state: up speed: 100 Mbps duplex: full
          mac: 44:87:fc:70:cc:84
          Drives: HDD Total Size: 250.1GB (4.7% used)
          ID-1: /dev/sda model: ST3250318AS size: 250.1GB
          Partition: ID-1: / size: 229G used: 11G (6%) fs: ext4 dev: /dev/sda1
          RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
          Sensors: System Temperatures: cpu: 18.4C mobo: N/A
          Fan Speeds (in rpm): cpu: N/A
          Info: Processes: 179 Uptime: 27 min Memory: 652.1/3945.2MB
          Client: Shell (bash) inxi: 2.3.56
            also $ inxl -f
            Now with 1600-900 resolution i can see the full screen but on the bottom screen is cut off about 5 inch and on the right side about 2 inch,if i lower resolution it gets worse
              [QUOTE=ivtec; hi guys Now with 1600-900 resolution i can see the full screen on the monitor settings after some struggle it was presented to a mode like wide screen sign ,it was hard to see it because all controls are in a weird place that are not very well marked ,thanks
              i
                make the smaller monitor primary and the larger secondary.
                  So its all working ok now?
                    Hi R_j as soon as you responded here after i had it working on both displays with resolution 1280-1024 0.0HZ ,which0.0HZ is weird since only resolutions under that show up on both displays with no other options and none work right even screw the graffics so much so i have to reboot,and the interesting thing is everytime i reboot it goes to a screen; ''see pics'' a log in with name and password witch i put in and it goes nowhere,then the only way i can go to my desktop is if i do Xubuntu GNU grub recovery mode,this Xubuntu 18.04 is giving me headaches with these 2 monitors
                      Ok guys i went the hard way which was reinstalling Xubuntu 18.04 and now it is working right set both monitors 1280-1024 75hz and seems both are set right now,keep my fingers crossed.
                        Try the setting of the monitor.. it have auto adjustment or manual setting the resulotion
                          Thanks guys ,you all at bad Caps are the best,and Bad Caps is the best Forum available on planet earth,thanks
