White area on mobo indicates positive?
    Ok, I am looking at a Asus A8N-VM CSM Rev 1.10GC, and all of the caps seem to be on backwards... All of the negative stripes on the capasitors are on the "non-white" area. the positive terminal of the capasitor is on the white half..... are they changing somethng?
    Re: White area on mobo indicates positive?
    They just don't follow the standard...
    Install new caps the same way the old caps are (i.e. follow the stripe on the cap, not the marking on the mobo)
      Asus did this for some reason on some of their motherboards. Don't know why, they just decided to do something confusing and different.
        I always call them "ASS BACKWARD ASUS".....yes the white area on the silkscreen indicates the positive pole for the caps.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
          Asus... always innovative
          lol
            Same goes for ASRock. The white side = Positive
              Asustek makes both Asus and ASSrock.....
              Team : 49813
              Join in!!
              Team Stats
                ASSrock... lol!
                sigpic
                (Insert witty quote here)
                  I'm laughing about this thread. When I started in electronics the positive lead of the capacitor was marked. The positive lead was also marked on the circuit boards in American designed products. Far from 'doing something different', Asus was doing things the way they always had been done before the Taiwanese got involved!!!
                  PlainBill
                    Asus + PcChips = ASSrock
                    Asus designs, PcChips [more correctly: Hsing Tech] builds.
                    Asus's bright idea to gain a chunk of the low dollar market.
                    For PcChips:
                    Hsing Tech = Manufacturing branch.
                    PcChips = Distribution branch.
                    [Same corporation.]
                    Not sure if ECS has the same arrangement as Asus or if PcChips and ECS simply merged.
                    Mann-Made Global Warming.
                    - Dr Seuss
                      Once in a great while someone will make up a bad silk screen to mark their boards.
                      When that happens just some of the cap polarity markings may be reversed.
                      Always best to make up a map of the PCB showing the original cap polarities before you start pulling caps.
                      - Dr Seuss
                        For PcChips:
                        [Same corporation.]
                        I think Hsing Tech is the name of the factory that ECS and PCChips have. When hardwaresecrets took a tour of the ECS factory there were PCChips on display next to ECS boards and pallets of PCChips boards around.
                          I always believed that ECS branded their low quality boards ECS and their VERY low quality boards PCChips.
                            That's what I said.
                            The ECS association with them is new in the last few years though.
                            Hsing Tech and PcChips have been around since the early 90's.
                            I spoke [via email, in the late 90's] with the General Manager of Hsing Tech about having a custom board built. I wanted 100. I didn't have enough cash for the minimum order of 10,000 boards.
                            - Dr Seuss
                              wait what...?!
                              ASRock = backwards too? I have been trying to fix an Abit IS7- E without most caps and it doesn't POST --- are they really backwards? you have to be kidding me
                              all that work only to take em out and put em back in the otherway around
                              NOOOOOOOOOOOOOOOOOOOOOOOOOOO
                                What does ASRock have to do with Abit?
                                - Dr Seuss
                                  My fault sorry, I mixed them up %)
