Vox mini 3 amp
    Re: Vox mini 3 amp
    Midibob,
    just like to thank you again for your assistance, daughterboard arrived and fitted
    vox back in action again legend!!
    jobo.
      Re: Vox mini 3 amp
      Hi Midibob,
      Any chance of one of those daughterboards?
      Owner says he tried the amp with a different speaker, and it died after half a minute.
      Chris.
        Re: Vox mini 3 amp
        Sent you a PM.
          Re: Vox mini 3 amp
          Thanks Midibob!
          Daughterboard fitted and working fine.
          Chris
            Re: Vox mini 3 amp
            Hi Midibob. Do you have any daughter boards available please?
            Cheers
            Ed
              Re: Vox mini 3 amp
              Yep,
              I've sent you a PM.
              Cheers
              Midibob
                Re: Vox mini 3 amp
                Hi Midibob,
                Could you please make some advice about Mini3 modding idea?
                I want to make a gap between modelling and output part of the amp to connect a looper pedal. This amp have two additional jacks -- phone jack and line input jack, so I want connect them by external wire.
                Phone jack have a switch that turn off loudspeaker when phone plugged in, so this switch must be removed. It's easy.
                But second part of this mod looks not easy for me. The phone amplifier and loudspeaker amplifier should divided. The sound from main input should go through modelling part and output to phone jack, and sound from line in should go to loudspeaker.
                Is it possible to make this mod?
                  Re: Vox mini 3 amp
                  Anything is possible of course but I can't advise you where you would need to break into the circuit to do what you want.
                  Unfortunately I don't have a diagram for the unit but from a visual inspection it would look like the output from the master volume goes to somewhere around the 'Aux in' jack where it is mixed together with the Aux signal. There is an SMD transistor here too but I don't know if that's part of the mixing circuit?
                  The switch on the phones jack disables the input to the PA and doesn't turn off the speaker as in most normal PA's.
                  Sorry I can't be more help as it's not something I've really looked into.
                  Happy New Year
                  Midibob
                    Re: Vox mini 3 amp
                    Thanc you for assistance, and Happy New Year!
                      Re: Vox mini 3 amp
                      I have mini vox 3 and have no sound from speaker. Only headphone jack works. How can I get your daughter board? I live in Ohio, USA
                        Re: Vox mini 3 amp
                        I'll send you a PM with the details.
                        Cheers
                        Midibob
                          Re: Vox mini 3 amp
                          My daughterboard arrived today and now my Mini 3 lives again
                          I also have a fully working original Mini 3 and side by side I can't really tell any difference between the original and the one fitted with the dughterboard.
                          Great little modification Bob
                          Ed.
                            Re: Vox mini 3 amp
                            Hi Midibob,
                            Could you pm me regarding purchasing one of your daughterboards. I have the same problem it seems.
                            Thank you!
                              Re: Vox mini 3 amp
                              PM sent.
                              Cheers
                              Midibob
                                Re: Vox mini 3 amp
                                Hi bob could you pm me , i'm from italy and i need one of your daughterboard . My minivox does the same problem as described in this forum (just phones output!).
                                Nerocorvino
                                  Re: Vox mini 3 amp
                                  Hi, there isn't an option under your profile to PM you?
                                  Can you PM me?
                                  Midibob
                                    Re: Vox mini 3 amp
                                    hello!
                                    Pls, send scheme of mainPCB of vox mini3.
                                    Can you PM me?
                                      Re: Vox mini 3 amp
                                      In case anyone else asks, there are no schematics available for the Mini 3. I've certainly not seen any.
                                      Midibob
                                        Re: Vox mini 3 amp
                                        Hi, I have the same issue with my Mini 3. Could you PM me with ordering details for the daughterboard?
                                          Re: Vox mini 3 amp
                                          PM sent.
