Re: Sharp Aquos LC-70LE650U
the bonded tabs are like tape which just pulls off. They have to be pull up from the front of the panel.... if you look close at the edge of the panel, you can see where the "tape" sits / rides. You do have to be careful as you can damage the tracks underneath which would be bad. It doesn't really matter where you start but they all have to be removed from the "bad side". Your chances of success are high as this "operation" has been probably performed hundreds if not thousands of times as it keeps one more set from the dump.
