I have a rather unusual question, but in the absence of a schematic i thought that someone here will be able or wiling to help me a bit. I have this Intel DP55WG board with a socket 1156 that doesn't want to turn on. I discovered that i do not have the 3V Std by so therefore i can't have any start-up.
The question it's as follows : were on the board it's located the stepdown from 5v std by to 3v ???
The board components test ok , i can't find any short , the 5V std by led it's lit, but no 3v std by and no voltage to the power on pins for the front panel. The voltage rails for the Sbridge are not shorted to ground, the SIO chip looks fine.
I also attached a picture, maybe it's easier like this.
Thank you !
Thank you !
