Re: mercury pc power supply only 5vsb supply.
The two transistors you checked should read about the same. The fact that one checks different shows there is a problem, remove the transistors and check them out of circuit.
This confirms the beeping is meaningless. the resistance of 0Ω or 1812Ω produces the continuity beep. so how in the hell can you go by that?
the vertical at base- continuous beep - black at base- continuous beep-value decreases- o-1812
