i have a sharp aquos model number 60le741e uk spec 230 volts it has been a excellent set for the last 2 years up until now ,it has developed a fault where it will turn off for no reason sometimes it will turn back on others i have to turn it on there is no patten it can be within 2 mins of first turning on or 6 hours later sometime the power light will come back on and stay on others it turns off and flashes 2 times ( from what i have read power supply fault code is 2 flashes) which would fit the faults the tv is having i have removed the board and there are no swollen caps theres is no build up of dust etc i have performed a hard reset by holding input and volume down to enter service menu left unplugged all night its not solved anything please i am at wits end a replacement power board is £75 which i dont have thank you
sharp aquos 60le741e help please
