Sceptre X405BV-FHD3HF02205 no power
    Re: Sceptre X405BV-FHD3HF02205 no power
    Do you know the background of the tv as budm says it looks like the ps.on signal is always on which comes from the mainboard could this tv took a lightening strike? which may of damaged the mainboard just a thought.
    is there anyway too test just the psu to rule it out by jumping pins? at least it will confirm a mainboard fault.
      Where are the names and pin number of the pins for CON4? You are not making it easy for us to help without putting the names of each pin.
      GND
      PS-ON
      ADJ
      BL-ON
      +12V
        My apologies, I didn't understand precisely what you were looking for. Hopefully the attached document provides the necessary info.
        Dick, I don't see a board in my TV that looks like the one in your photo. If I'm missing something, please advise.
        The TV failed progressively. Initially, if I unplugged it, waited a few minutes and tried again, it would sometimes come on and operate normally for as long as it remained on. The frequency of coming on after this re-boot increased quickly until it won't come on at all - just the red standby light.
        Because of the progressive nature of the failure, it would seem unlikely for a lightning strike, but may be a possibility.
        Again, thank all of you for your patience and help.
        Paul
          So the BL-ON (Backlights ON) is not present, that is from the main board, other Voltages and signals are fine.
            Paul
            Sorry if it's the wrong board. What are the voltages on Connector 4?
              http://www.shopjimmy.com/sceptre-kw-...t-inverter.htm
              Sceptre KW-PIV400102A Power Supply / Backlight Inverter.
              Pictures provided by shopjimmy
                Thanks budm for the correct pictures.
                  Connector 4 voltages are shown on the attached document. "BL-ON" voltage appears to be .20
                  Paul
                    So Budm is correct and you are missing the Backlight On from the main board for some reason.
                    Edit:
                    Whats the part number on U1 on the underside of the board?
                      BTW, the PS-ON should toggle HIGH and LOW when power switch is togGle on and OFF, if not, then you have problem with not just the BL-ON signal but the PS-ON too.
                      At this point it is safe to say that the problem is on the main board.
                        Voltages do not change on BL-ON or PS-ON when the power switch is pushed on/off.
                        The part number for U1 (UA1) is:
                        TPA3110LD2
                        23Tg4
                        CO4L
                        The part number for the large chip U100 is:
                        MSD3391DS
                        A7MHA93ZB
                        1214D
                        Thanks again, if you guys are willing to continue to try, so am I!
                        Paul
                          Is it likely that the EEPROM on this board has failed? I notice the replacements are commonly available. Would this be worth a try?
                          Thanks again for all your help.
                          Paul
                            Yes epprom failure so common on these junks.
                              Bought a replacement EEPROM from ShopJimmy, soldered it in and TV works perfectly.
                              Thank you guys for your help and guidance.
                              Paul
                                Hello, This is my first real post here other than the intro.
                                It looks like there have been 2 successful repairs to this model from this thread and I just wanted to let you know there are now 3.
                                I have one of these that just quit about 10 days ago. I googled around and came upon this thread. I followed what was posted on the 1st page and when I saw the results for diodes D10, 22, 23 and my D10 was reading 0v compared to the others I gambled and figured that was the culprit since my results were similar to the original posters. Ordered it from digikey, received it today and soldered it in place and so far so good. It's working as it was before.
                                I actually enjoyed fixing it and saved $300 or so.
                                I'm going to keep my eyes peeled for others with T.V. issues and try to repair those as well as I have free time I need to fill so I will be back.
                                Thanks,
                                Kirk
                                  Hi everyone, sorry to bring this back from the dead. I am having the same problem that plbrand was having with his sceptre tv. STBY light on...won't power on. Same model, same boards. I am also getting the same readings on the pins. Is there a way to bypass the main board with a jumper so i know for sure that it is the problem? I am having trouble finding an EEPROM that matches my board #s exactly and according to shopjimmy it has to be EXACT....the closest is 1 number off. According to SCEPTRE they sell the whole board...but I would still like to be sure. Thank you,
                                  Trevor
                                    try freeze spray on the eeprom ic if the set now starts up ok you can remove the ic and freeze it again and copy the data the write the data back too a new ic i know this is not the same make of tv but this video gives you a idea what too try
                                    https://www.youtube.com/watch?v=Qy8f...t=WL&index=114
                                      I have repaired this TV once and posted in this thread a few years ago saying so. It now has the same symptoms as plbrand had on his and is still in the such a state that I can fiddle with the button and unplug/replug and get it to come on so I don't have it apart yet. plbrand replaced the eeprom which I am just going to try.
                                      Would someone be so kind as to use one of the many pics of the board in this thread and point out where the eeprom is?
                                      I can handle it from there.
                                      Thanks!
                                        Thanks!
                                        if you look on the shopjimmy web site im sure when you search for the eeprom it gives the board number location
                                          Oh, I see that now. Thanks for the tip.
