Fujitso w26361-w2912-z3-02-36 bios need
    Hi everyone I am new to this forum can somebody please help me give me a working bios dump file for my desktop motherboard FUJITSO W26361-W2912-Z3-02-36 SERIAL2990-A11 GS 3. Thanks in advance i need this file urgent please
    Re: Fujitso w26361-w2912-z3-02-36 bios need
    anyone please help me share the working bios file please thanks in advance
      I post this wrong section but i just want a help please i am new to this forum i have fujitso desktop motherboard cannot turn on no power Ive measured the voltage is present even in bios chip there is 3.3v. please help me share bios file for this model. serial number is2990-A11 GS 3.I have attached the original bios bin file can someone fix it for me please and also i attached the motherboard image. thanks in advance
        bios can not fix your problem.
        disconnect 4pin from power supplay and connect just 24 pin.(cpu supply)and turn on.see what happen.
          thank you for the response I disconnect the 4pin and connect only 24 pin power supply fan turn on but cpu fan not turn on what should i do next please help me thanks
            update: after solder back the bios chip in the board i put it back the 24 pin and 4 pin now the board works thanks for the response boyebaran
              update: after a couple of hours motherboard working but when i turn it back again now i cannot turn on even i put back the 24 pin only still cannot turn on Ive noticed before when i plugged in the psu the cpu fans turns on very fast and now cannot turn on back please help me any advise please
                have you backup bad!!!!
                  thank you very much bios good work
                    thanks for the bios file
                    and you need to check the power supply box
