LA-D993P No power no charging
    hello
    When you press the power button, the light turns on and off. It was working normally until a day ago. +3VALW ,+5VALW and power_sw have 5 volts, won't charge and won't turn on
    P65F
    LA-D993P REV 1.0
    Re: LA-D993P No power no charging
    After the lights turn OFF - do you still have the +3VALW ,+5VALW and power_sw voltages?
    Are you using the original and official power adapter ?
      it was working with non original charger. The battery was not installed. When I arrived in the morning, I noticed that the device was not turning on. I tried with another original charger and it still didn't turn on.
      +3VALW ,+5VALW and power_sw 3 volts have
        See attached.
        1) Start with the charger IC @ PU300.
        Attach a known good power adapter -> meter in DC volts scale (30v or higher).
        Carefully (!) measure the voltage of each of the highlighted IC pins.
        Interested in:
        Vcc (pin #28)
        REGN (pin # 24)
        ACDET (pin # 6)
        ACOK (pin # 5)
        ACDRV (pin # 4)
        Post each measurement.
        2) Next, remove all power / no battery.
        Meter in resistance mode -> check the resistance across the mosfet pins:
        PQ306 & PQ302
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Post each resistance measurement and the scale used on your meter for the checks. As per above sticky from @Pienov - often the 2nd mosfet gets damaged.
        reference:
        http://electronicsbeliever.com/how-t...-is-defective/
        * see the section on resistance checks
          Vcc (pin #28) = 19.7 Voltage
          REGN (pin # 24) = 6 Voltage
          ACDET (pin # 6) ACOK ( = 2.7 Voltage
          pin # 5) = 3.3 Voltage
          ACDRV (pin # 4) = 25.8 Voltage
          PQ306 diod mode : 0.465 /
          source (1-2-3) & drain (5-6-7-8) = resistance mode :465 ohm
          source (1-2-3) & gate (4) = resistance mode :611ohm
          gate (4) & drain (5-6-7-8) = ---
          PQ302 diod mode : 0.513 /
          source (1-2-3) & drain (5-6-7-8) = resistance mode :513ohm
          source (1-2-3) & gate (4) = resistance mode :606 ohm
            1) Charger IC voltages look good.
            2) The mosfet resistance readings are not ok if the readings are indeed in ohms.
            3) Remove all power and with flux and hot air, remove PQ302 off the board. Careful of the air pressure so that other tiny nearby parts do not go flying.
            Then wait for the removed mosfet to cool and check the resistance in the same way of the part that you have removed.
            Is the removed mosfet still with these very low readings?
            Also check the resistance values of the PQ306 mosfet (now that PQ302 is off the board and should not influence the measurements).
              sorry
              I typed wrong kΩ
              https://we.tl/t-cfstD6JZ3t
                Then the resistance appears to be ok for the mosfets.
                Before placing the mosfet back onto the board, check the resistance to ground of the removed mosfet pads:
                source (1-2-3)
                gate (4)
                drain (5-6-7-8)
                if the power is not remaining ON for the main power rail then you may have an excessive current draw which is being sensed -> could be a broken current sense circuit which will result in the same observation. Or the bios of the EC controller may need to be reflashed.
                  source (1-2-3) = 398 kΩ
                  gate (4) = 416 kΩ
                  drain (5-6-7-8) = 130kΩ
                  i tried the bios
                    Looks ok.
                    Check the resistance to ground of each coil (inductor).
                      I checked the coils, there is no low resistance or short circuit.
                      When the device was in its last working state, the battery was not plugged in and the non-original charger was connected
                      The PS_ID line goes in MEC1404. Could the mec 1404 be faulty? Due to fake charger
                        What is voltage of PS_ID ?
                          PS_ID =3.4 Voltage
                            I haven't been able to fix the problem yet
                            There is a working motherboard. does it help fix the other
                              Yes, it can help.
                              Does the working unit use the same or different power adapter?
