I have a iMac G5 in which i can't get the 3rd light or video to post. The unit chimes up, I hear the superdrive engaging and the 1st and 2nd light come on without problems. I tried know working power supplies and no luck. I even tried a working LCD inverter and no luck. I did a visual inspection of the caps on the mobo and now look like there swelling or blown. IS there anything else I can do to check? thanks in advance.
imac G5 20" 3rd led not turning on?
Re: imac G5 20" 3rd led not turning on?
Wired, I just hooked up an extra screen lying around and it worked! I removed the tested screen and hooked it back up and the screen now works. The only thing I am concerned about is when turned on the screen flashed black twice and then shows the white apple logo. Sigh of a bad BGA?
Ok. That sounds more like a bad cable or connector to the panel. Try not tightening the screws to far and see if it stays. Had to fix the cable connector to the mobo on a replacement panel a few months ago that did the same thing. Intermittent connection in the plug under all that tape and shield.veritas odium parit
