Sorry to sound like a n00bie
    What are the differences between a MOSFET and a capacitor. The purpose of function?
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    16 GB AData XPG Spectrix D41
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    Re: Sorry to sound like a n00bie
    MOSFET's supply power by reducing voltages. Capacitors smooth that power out and hold a small reserve for burst power usage.
    Ludicrous gibs!
      Hmmmm ... MOSFETs can be used as amplifiers or switches. As an amplifier, a relative small signal controls a larger voltage or current. As a switch, the control voltage turns on or off a larger voltage or current. In the context of a VRM, the MOSFET is a switch that chops V(In), producing a square wave, which is rectified and filtered into a lower DC voltage. Controlling the duty cycle [T(On)/T(square wave)] controls the output voltage.
      A capacitor is used to store energy and filter (smooth) a DC voltage. In a VRM the capacitor helps filter the square wave into DC, and handles current transients.
      PeteS in CA
        BTW, no need to apologize for "basic" electronics Qs. We all start with the basics at some point in our lives.
        PeteS in CA
          MOSFETs
          capacitor
          typical capacitors on this forum
            MOSFET= Metal Oxide Semi-conductor Field-Effect Transistor. So basically, a transistor
            "Its all about the boom....."
            Guns kill people like spoons made Rosie O'Donnell fat.
            We now return you to your regularly scheduled drinking.
            "Fear accompanies the possibility of death.....calm shepherds its certainty"
            Originally posted by Topcat
            AWD is just training wheels for RWD.
              MOSFETs and JFETs (Junction FET) are voltage controlled devices, in which the gate current (other than charging gate capacitance) is tiny or less. Bi-polar transistors are current controlled devices, with the base curent, depending on the device, ranging from u-Amps to Amperes.
              PeteS in CA
