G580 black screen
    G580 black screen
    Power is ON but black screen, Plt_rst signal present,
    voltage on ram slot dimm1, 1D5V_S3 & 0D75V_S0 are ok,
    I changed many rams but condition is same what will be possible solution? Any suggestion?
    Re: G580 black screen
    Anything on external display
      why u think it have something with ram
      as first reflash bios. have some of this with corrupted bios
        try flash bios this model is common for bios issue
          Does usb kbd numlock glows?? I mean mb boots?? If so, bios flash should be the first step as suggested by many members.
            Nothing on external display & Usb keyboard numlock or capslock led doesn't glows.
              already flashed bios bt condition is same.
                At first time I checked on dc supply and I got current signal is upto 86-87mA, thats why i was thinking ram issue.
                  Some measurements:
                  5V_S0 OK
                  3D3V_S0 OK
                  1D8V_S0 OK
                  1D5V_S0 OK
                  0D85V_S0 OK
                  0D75V_S0 OK
                  VCC_CORE OK
                  RTC bat 3V
                    VCC_GFXCORE dead-
                    Associated MOSFET PU4402 gets DCABATOUT OK.
                    No signal on the driver PU4401: PWR_GFX_CORE_DRVL, PWR_GFX_CORE_DRVH, and PWR_GFX_CORE_GPWM all have no signal.
                      What is the voltage on PIN30 of ram slot??(DRAMRST). Should be around 1.35-1.50v. If this signal is missing then also you wont have GFX core voltage.
                        Yes, signal is missing.
                        how can I solve this?
                        Thnx for your reply.
                          Check voltage on Q3703
                            sorry brother, He took his laptop back today.
                            Thank you for all your help.
                              You cant help this as your customer is in a hurry.
