Hi All
Got givern this TV as a scrapper. Had a quick look anf found 2 100MFD caps on the power PCB bulging. Changed the caps and the set started up. Took a look at the picture just a mass of verticle coloured lines. First thought TCON board or the LCD panel no good. As I was thinking about this the top third of the screen started to show a normal picture. After a few more minuits the normal picture extended to half way. Kept watching but nothing else happened just a normal picture in the top half and a mass of verticle coloured lines in the bottom half.
Still thinking panel or Tcon board faulty turned the set to stand by. Switched it on again and was rewarded with a full normal picture. Now more convinced I got a replacement Tcon board. Result, I thought as soon as I turned on full picture.
Not so the next day when I tried the set same symtems as before. Switch on just a mass of coloured verticle lines. After 3 or 4 minuits top third of picture appears then half a picture. Restart set full normal pictuer appears.
Never seen this fault before. Have any of you experts got any ideas before I condem it as having a faulty LCD panel.
Any help or ideas would be much appreciated.
Regards Dave
Regards Dave
