How can I convert hp g62 discrete to uma
    Re: How can I convert hp g62 discrete to uma
    Originally posted by memoslar View Post
    Hi, i have DAAX1JMB8C0 with the processor on board. Will it work? I tried except the seventh picture. But its not powers up.
    In 7th stage cant figure out the position of the capacitors.
    I have one difference in picture 2. I had 75 ohm resistors instead of 70 ohm in r497 , r498, r499
    Hi memoslar, Here is your answers:
    1) 7th stage pic-you need to put 470uF capacitor at PC132 and then make a jumper from PC132 positive to Q9 mosfet on pin1
    2) 75 or 70 ohm resistor hardly matters. You can use anything between 60-80 ohm. It will work.
    Boardview was already uploaded by me. Use that to locate components.
      memoslar is it works for you ?
        It works dear as long as you do it correctly. 100% tested by me.
          Thank you very much ! it worked good!! God bless you
            but today i cant remember this, how can i solve this i try to but cant remember .......sorry guys
                HP 634649-001 G62 -450sv how to CONVERSION Dis To Uma plz help ??
                  pc132 capacitor can't need.. plz help
                    Here is the conversion details+Boardview(without which its very difficult to locate components
                    Enjoy
                    i tried.it is working but no video on vga port and hdmi.my vga problem solved with schema.
                    thanks..
                      The DAAX1JMB8C0 with the processor on board has another simplier convertion.
                        hp g62 mb:pm_i_hpc_s mv_mb_v3
                        pj19 open
                        RI55 SHIFT RI51
                        RI53 SHIFT RI56
                          can you please share the simplier convertion for DAAX1JMB8C0
                            it is here
                            https://www.youtube.com/watch?v=PJMQ6ySvTrs
                              Originally posted by teknikbursa View Post
                              this is not the full guide, missing a lot of steps
                                Do you have all the steps?
                                I've done the steps from YouTube, but no video.
                                  Enjoy
                                  This instruction is 100% bullshit.
                                    Nope, perhaps your understanding of schematic diagram is. Have succesfully converted atleast 5-6 motherboards.
                                      Enjoy
                                      Hi, I saw those components to add, can I find them on a g62 motherboard with soldered cpu? Or can you tell me what the components to add are called?
                                        thanxxx
                                          hello how do you solve the problem with vga and hdmi?
