LED chips for backlight board?
    hi im trying to do some trail and error trying to repair a led tv backlight board that had 5 bad leds
    i removed the led chips and would like to buy replacment led chips
    ..not sure what to look for when buying...ive seen some 6v ones on ebay for led tvs... the chips have 2 pads on bottom one larger than the other and are about 3x3mm size..very small
    just looking for something generic that would work with most backlight boards....doesnt have to be exact oem replacment..just something that will function
    what specs would i need to be looking for? voltage? watts? etc etc
    Re: LED chips for backlight board?
    pe board is not
      tech propblems with pc..i hope board is fixable
        Have you got a pic of the LED? it's difficult to see from your pictures.
        Do you have a backlight tester to check the voltage of the LED diode or strip divided by number of LED's?
        You will need to know the voltage.
        To find the correct LED you will need to measure as accurately as possible the width & length ie; 2.8mm x 2.8mm would be a (2828) type, or 2.8m x 3.5mm would be (2835) type so on & so forth.
        Secondly check the bottom pads against the ones you are buying they should be identical.
        Thirdly the top of the LED will have some variation but match as close as possible to the ones you have.
        Here are some examples of ones I purchase, they are very cheap so I usually buy a variety to keep in stock.
        https://m.aliexpress.com/item/324738...ddresstype=600
        http://s.aliexpress.com/ri6R3Eja?fro...y to Clipboard
        http://s.aliexpress.com/JJZbyIjY?fro...y to Clipboard
        With the snapped strip I would scratch some of the coating off & jumper together with wire.
          Thank you...yes they r super cheap...so you recommend those 3 sizes?
          Not sure what i have ..but ill look on ebay for those
          Aliexpress shipping costs too high to usa
          What about voltages?
          Are the smaller ones 3v and the parger ones 6v?
            And am i looking for cold white?
            Warm white?
              Ill try scratching..
                Yes those 3 are common, you will see the last link is the 6v.
                Voltages are not size dependant.
                As for the warmth, I can usually tell by eye when I light up the panel with my backlight tester, I find if it's a blueish tint it's cool white & if white light it's warm.
                You should really invest in a backlight tester;
                This is the best one;
                https://m.ebay.com/itm/LED-Backlight...from=R40&rt=nc
                  Ill research aliexpress..shipping free?
                  So u recommend
                  2828
                  2835
                  3535
                  What about 3030
                    Thats too much.for tester...can you recommend a cheap version....i dont need fancy...just need cheap
                      Most led tvs ive taken apart are bluish not warm color
                        2 x AA batteries lol
                          Oh that easy lol...i have a multi regulated ac adapter incan use..it has 3v 5v 6v 9v settings
                            So u recommend
                            2828
                            2835
                            3535
                            What about 3030
                            Yes shipping is free on AliExpress unless you want Expedited.
                            I recommend measuring the ones you have.
                              thanks i just bought some 2828 and 2835 on ali express and bought 3535 on ebay
                              is 3030 common or not so much?
                                how do i know if the led i have are 3v or 6v?
                                  i guess if i shoot 3v into them and they dont light up but with 6v they do then they would be 6v
                                    i think they are 3v because when i powered on the board only 3 lights out of 8 lit up and it showed like 8.8v...and then shut off..i would imagine the voltage is variable ? so if the other lights were good the voltage would have been 24v or so?
                                    other question is some led tvs have leds in the hundreds..i would iimagine these are lower voltage leds? i cant imagine them being 3v if there are hundreds of them....dont think you would have 300v going to led strip??? or am i wrong?
                                      You need to find out if the big solder pad is Anode or Cathode, it is important for heatsinking of the LED.
                                        you need to find out if the big solder pad is anode or cathode, it is important for heatsinking of the led.
                                        +10
