I have a friend's Affinity LE-3252 LCD TV that doesn't power on, only when it wants to. Like on the 50th repeated try with the button or remote. It does have the red standby LED which goes green when it finally decides to turn on. Everything works great when on. HDMI worked fine with a chromecast on it. Audio ok. All buttons work on the panel and remote and it turns off fine too. But then it's another 50-100 tries to get it to turn on again.
When in standby mode, all 4 vregs chk ok with same voltages as in this post. 3.3, 2.5, 1.8 and 3.3V:
https://www.badcaps.net/forum/showpo...97&postcount=4
I haven't found much online about these having bad caps. They all seem ok. TCON (lower edge of TV below speakers) seems fine because display works fine when it powers on. The power/main board is all in one and has PCB number TP.MS3391.P83 and D12080996-0A02533 on a bar code label. See pics. Manufacture date 201208.
ShopJimmy's closest board model is a .P91 for Element ELEFW327 TVs which are almost identical to the Affinity one. There are like 18 diff types but they don't have the .P83. Prob obsolete/discontinued...
http://www.shopjimmy.com/catalogsear...=tp.ms3391.p91
These posts say that the common issue with the ELEF models is the EEPROM [UF11 on both boards - .P91 and .P83 (mine)]...
https://www.badcaps.net/forum/showthread.php?t=38533
https://www.badcaps.net/forum/showthread.php?t=38980
Emailed this info to SJ to see if they have this particular EEPROM.
Any help appreciated
Thanks!
Thanks!
