Hey guys! I've been trying to fix this tv i had laying around for some time, was wondering if you could help me find the problem because i ran out of knowledge, i'm just a self taught repair wannabe so i apologise in advance for my lack of knowledge
So, one day this tv stopped turning on, only flashed the red light once and then stopping, i took it apart and looked at the power supply, noticed two blown capacitors (the red circled ones) and replaced them, soldering was a bit wonky because one was longer but its the right farad and voltage, still nothing, no turning on no pic.
Then i replaced every capacitor i could get my hands on, nothing.
I tested fuses and diodes (well i think i did, i'm not so sure of my work ) they seemed all fine.
Searched the schematics of the board EAX65391401 3.0 and started trying to understand something.
I measured the voltages at the connector that goes in the logic board, 3,5v 24v and 12v are there and perfectly fine
Then i measured the backlight current that should be 117v and found that it was putting out approx 140v
Oh and today i noticed a really low crackling noise (bzzzzzzzz) coming from the bottom right of the board, like an electric dispersion but could not find where it was
Tl;dr Tv didn't turn on, only one red blink, Replaced bad caps on powersupply, still nothing, backlight line puts out 140v instead of 117v, crackling noise on bottom right of the board, i have no idea of what i'm doing
Sorry for the long post, i tried to put as many info as possible, tried to follow the guides sticked at the top but nothing,
Am i better off buying a new board or is there hope?
Thanks a lot
Thanks a lot
