Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Abit - Asus - Aopen
Thread Tools Display Modes
Old 02-11-2019, 07:26 PM   #21
Sparkey55
City & State: OK
My Country: USA
I'm a: Professional Tech
Default Re: IPIBL-LB loses BIOS settings after power off
Do you use the same HDD for Windows 7 and XP?
When you install the OS are you connected to the internet via a firewall?
Have you zero filled (wiped clean) the HDD before installing OS?
Have you scanned your installation and update media for rootkits?
Trying to narrow down if hardware or software problem
Your PSU has not been ruled out nor has the CPU as yet.
Sparkey55 is offline   Reply With Quote
Old 02-12-2019, 01:15 PM   #22
SMDFlea
City & State: York
My Country: UK
I'm a: Knowledge Seeker
Have you checked the crystal .
SMDFlea is offline   Reply With Quote
Old 02-12-2019, 05:39 PM   #23
pfrcom
Oldbie
City & State: Melbourne, Victoria
My Country: Australia
Line Voltage: 240v
I'm a: Hobbyist Tech
Quote:
Originally Posted by Sparkey55 View Post
Check to see if you have the switches connected in the correct pins on the header.
No switches connected - just motherboard on a wooden surface, touching jumper momentarily to necessary places
__________________
better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
pfrcom is offline   Reply With Quote
Old 02-12-2019, 05:49 PM   #24
pfrcom
Oldbie
Line Voltage: 240v
No
No, completely isolated
Yes, using manufacturers' diagnostics
No, but I am using Win7 SP1 with update, downloaded from Digital River when it was available, and SHA1 checked before burning to DVD
And same DVD has been used many times, without issue
Have tried multiple PSUs and CPUs
Old 02-12-2019, 05:49 PM   #25
pfrcom
Oldbie
Line Voltage: 240v
Quote:
No - how do you check crystal?
Old 02-12-2019, 07:10 PM   #26
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Quote:
Originally Posted by pfrcom View Post
FWIW, other weird behaviour is, if I short Reset pins on Front Panel header, more often than not there's a delay, then it powers off
At that point just shorting the Pwr pins won't start it - I have to switch power off & on before it will start again
So I need to remember to use Ctrl-Alt-Del for reset
Something fundamental seems to have gone wrong with its electronics - reckon I'm
That is quite strange, indeed.
My IPIBL-LB is in a HP PC, so it doesn't have a reset switch. But wonder if will do the same thing. If not, then for sure something may not be quite right with yours.
With that said, perhaps consider giving the motherboard a wash with detergent and warm water, then dry for a few days. Maybe something conductive has gotten under one of the chipsets and is shorting something? I know that using case screws with non-smooth heads will sometimes produce solder and/or metal shavings where the screw head grinds against the motherboard or case. If these shavings got underneath a BGA chip, I think that could cause intermittent trouble. So when in doubt, I wash things and make sure to force plenty of water under whatever BGA chip I think may have gotten affected. Never really had a case where resolved anything, but for the tiny off-chance that it might be possible, I still do it.
Old 02-14-2019, 03:49 AM   #27
Sparkey55
City & State: OK
My Country: USA
Another thing to try if you have a seperate chip programmer, reflash the bios chip, that will clear it out for sure. Or buy another chip with the bios preprogramed.
I had a Epox motherboard that would stop posting with a C1 error and could not flash on board so took it out and reflashed in programmer now works fine.
Old 03-07-2019, 06:44 PM   #28
pfrcom
Oldbie
Line Voltage: 240v
KUDOS to Sparkey55
I desoldered its MX25L8005 BIOS chip and reflashed it with my Rube Goldberg setup - https://www.badcaps.net/forum/showpo...55&postcount=9
Involving:
1. Erase
2. Blank check
3. Program
4. Verify
5. Dump
6. Compare dump to original
So it should have been well & truly cleared out
Didn't feel that confident after all the setbacks along the way, but after the acid test of booting an existing Win7, then shutting it down and turning the power off, it didn't produce the dreaded message after starting again
Even left it powered off overnight to confirm no message in the morning, before posting this
Has certainly reinforced my opinion about Macronix chips being cheap & nasty, compared to Winbond or SST
Thanks to everyone who contributed
Old 03-07-2019, 07:16 PM   #29
momaka
momaka's Avatar
My Country: U.S.A.
Yay! Good to hear a success story here!
I wonder if that got rid of the random BSODs you experienced too.
I raise this question, particularly because I pulled my HP PC with the same motherboard, and first several boots, it was doing some weird things, including throwing a BSOD once or twice. But after a day of use, all trouble went away. I then turned off and disconnected the PC for a few days to see if the issue is perhaps cap related (it does have a Bestec 250-12Z PSU that hasn't been recapped... though all caps appear OK visually... which we know doesn't mean much, but still.) So far, though... it's been OK.
Anyways, I'll keep this thread in mind if I see any more odd behavior with my board. In any case, really glad that you were able to fix your and that you updated the thread.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
