Acer aspire 5742z no power / dead
    Re: Acer aspire 5742z no power / dead
    what do you mean take it down??mean remove it??
      can you help me how to test the mosfet in mode?and which pin should i connect the tester in diode mode thanks..
        Hi mate, are you still struck with this Acer or did you manage to fix it?
          help me pls
          the board is already shows charging the led is in orange mode but has no power...
            help me pls
            Hi mate,
            If the Motherboard charging LED is orange (Please check current pull up - it should be more than 1 amps) then charging circuit is good. The next thing you need to check Coil PL46 and PL47 for 3.3 and 5 Volts respectively - If yes go to U16 (EC / SIO chip) Check pin 117 :PBTN OUT# it should read 3.3 Volts. If yes press the power button and check Pin 13 (PLT RST) it should give 3.3 volts output for turn ON. If no voltage from pin 13 check SPI bios (re-flash) first and then replaced SIO chip.
            Cheers
              thanks i will check it now i will post the results
                i think the power button circuit has a problem how can i check it??
                  Check voltage 3.3 Volts on the power button - If yes : press the power button and see the voltage drops to 0 volts - If yes the power button circuit is OK. Check the bios and EC.
                  Cheers
                    this the diagram of circuit of switch
                    there is 3v in the r409 and 3v in the ec_on but in the button there is no volts
                      the button will be short remove button and chq.
                        i already remove the power button..the button is ok i check the voltage in terminal of switch without switch still no voltage
                        the switch is connected to diode and resistor
                          is there any posibility to power it on without using power button?or is there any terminal to power it ??
                            in JLED1 connector, momentarily short pin 7 and pin 8.
                              i already short the pin 7 and 8 of jled1 still no power..can i ask which pin should im going to meausre the voltage of power in the jled1,because only pin 1 and 2 shows 3v..
                                pin 7 should have 3.3v or 17v. if no voltage is found, you probably don't have +3VALW.
                                  I am also having the same problem I'm getting voltage on pin 7 so know power going to the motherboard but the laptop is still dead don't know what to check next
                                    Hi I am having a problem on this same board. 19V input connector shows 19V ok. Led 3 is blinking. On PL42 it show power fluctuation. its going down from 19V to 16V, 13V, 10V, 9V. I found a cap PC1011 is short circuited and i replaced it. but the problem still. I replaced PU17, PU1000 also but problem not solved. anyone having any idea ?
                                      Hello1 I HAVE A PROBLEM WITH ACER ASPIRE 5742 ZG. POWER UP JUST FOR BATERY, PLUG IN AC POWER ADAPTER, NOT POWER UP. POWE BUTTON VOLTAGE IS 20V. ANYOANE CAN HELP ME?
