I am trying to diagnose a refrigerator motherboard and am at a quad op amp LM324. The fridge has 4 fans, one of them, the condenser fan, works properly, but the three evaporator fans do not turn on but work fine when 12VDC is directly applied. The fans have a 3 pin connector, power and sensing, I read the motherboard senses if the fan is spinning.
According to the schematic, attached, it seems, going backward from the connector CN75 each fan goes to a transistor TIP42C then to the quad op amp LM324 and then to the main chip with all the brains of the organization S3P848A.
I get no power at the connector CN75, I have removed the condenser fan transistor and another one from a non-running fan and they both test the same. I have swapped them and everthing works as it did before, so I assume that means they are good. I take from this that the other two probably are working as well. If a transistor is broken would its heatsink get warm or would it be cooler even though it is in the same environment/ambient temperature?
As you can see from the schematic there are a lot of resistors, caps, diodes in between, all visually look ok but I know this can mean little. I can't see testing them all so I am hoping to see if the problem is with the quad op amp.
Then I went for the op amp.
When idle I get 12V on Vcc and the output pins,1,7,8,14,
on the - and + inputs I get for pins :
2 bounces +/-
3 solid +
5 solid -
6 solid -
9 bounces +/-
10 solid +
12 solid -
13 bounces +/-
When the refrigerator call for cooling and kicks on I get:
1 1.58 14 -1.18
2 -4.85 13 -6.65
3 -4.55 12 -6.5
4 4.55 11 -9.9
5 -4.95 10 -7.1
6 -5.08 9 -7.07
7 -0.13 8 -0.93
As I do not know the proper operation of a quad op amp I do not know how to interpret these values. If someone could let me know if it looks as if it is working properly or malfunctioning I would appreciate it.
Is there anything else that I can test or clarify? If the op amp is working correctly would it then seem that the main logic chip is at fault and thus a new mobo is the solution. Knowing the all the evaporator fans work fine on 12VDC is it even possible that they are the cause?
Many thanks for reading and any assistance you can provide.
2 bounces +/-
3 solid +
5 solid -
6 solid -
9 bounces +/-
10 solid +
12 solid -
13 bounces +/-
1 1.58 14 -1.18
2 -4.85 13 -6.65
3 -4.55 12 -6.5
4 4.55 11 -9.9
5 -4.95 10 -7.1
6 -5.08 9 -7.07
7 -0.13 8 -0.93
