Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Audio Equipment
Thread Tools Display Modes
Old 09-21-2022, 04:50 PM   #1
toty79
City & State: termini imerese
My Country: Italia
Line Voltage: 220VAC 50-60Hz
I'm a: Knowledge Seeker
Default Car Audio Delco identification and restoration / repair
Hello to all friends and welcome back
I am struggling with a complete restoration of a Delco GM car radio, I have already taken these car radios in the past but this is a bit more complicated and has many problems, in the meantime I ask if anyone knows the exact model in order to trace a possible repair scheme, I have if someone and they have it I would be very happy, I am attaching photos and I also ask what is the purpose of that two-wire connector that comes out from the back (orange-brown) the radio turns on with the display completely off, the mechanics make strange and non-strange noises accepts the tape, the audio is distorted on all channels, first of all I would like to start with the display off, I have only redone some soldering but nothing has changed, I have also found two faulty micro-lamps have been changed and now they turn on but the display always remains off, is it possible that it has something to do with the small connector on the back?
thank you all
File Type: jpg 6a8d752b-25d3-4567-a45b-0316b90c33e8.jpg (356.7 KB, 17 views)
File Type: jpg 48d2b2ad-3b4e-4d97-b393-cb1b451d10a4.jpg (273.5 KB, 17 views)
toty79 is offline   Reply With Quote
Old 09-21-2022, 05:12 PM   #2
keeney123
Lauren
City & State: North Adams MA
My Country: United States
Line Voltage: 120VAC, 60Hz
Default Re: Car Audio Delco identification and restoration / repair
Seems to be a model number 16066335.
This site may help.
https://classicoldsmobile.com/forums...-1990s-150403/
keeney123 is offline   Reply With Quote
Old 09-21-2022, 05:36 PM   #3
redwire
City & State: Alberta
My Country: Canada
I found some info here https://pcbisolation.com/blog/repair...s-delco-radio/
redwire is offline   Reply With Quote
Old 09-21-2022, 08:14 PM   #4
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
I believe the 2 pin plug is for constant +12v (memory) and display lamp (controlled by dash lamp dimmer)
R_J is offline   Reply With Quote
Old 09-21-2022, 08:48 PM   #5
toty79
My Country: Italia
Thanks a lot R_J
I just connected the red to the + 12v but I still have a display turned off, what should I connect to the brown cable?
obviously I feed everything on the counter
Old 09-21-2022, 09:04 PM   #6
R_J
City & State: ☻
My Country: Canada
The Red wire is likely for the constant memory backup, the brown should be for the display, connecting it to +12v should light the display
Old 09-22-2022, 02:21 AM   #7
toty79
My Country: Italia
Just tried + 12v on the brown cable too but I still get display off, troubleshooting tips?
Old 09-22-2022, 08:43 AM   #8
R_J
City & State: ☻
My Country: Canada
See if this is close.
Old 09-22-2022, 12:28 PM   #9
keeney123
Lauren
Quote:
Thanks RJ for helping out. I believe he will be able to use this schematic for the display troubleshooting. He just needs to remember his wrist strap to ground when working on it. At per instructions on page 26.
Old 09-22-2022, 06:28 PM   #10
toty79
My Country: Italia
R_J thanks you are fantastic
Keeney123 you are absolutely right and almost identical and you will give me a lot of help, the only question at the moment looking at the schematic and how to identify the IC and transistors as they have a dedicated Delco code and also in the parts list sheet they are marked with a code that does not carry to nothing as equivalence I maybe have the datasheet of the component to be tested, for the moment I thank you all and I will keep you updated
Old 09-22-2022, 07:44 PM   #11
keeney123
Lauren
I believe the DM on the chip may stand for Delco Motorola. This could be wrong. It just would make sense to have an IC manufacturer build your ICs with your design and then put the product together with your name on it.
Some sites list the DM as Delco Modules. Would be interesting to investigate further.
The DM Delco IC are available on Ebay.
Another place to buy https://www.ceitron.com/semi/ceidelco.html
Just when buying from above people be cautious.
Delco is going to want you to buy their product that is why no listing. I guess when troubleshoot one would have to look at the schematic and figure out what to expect. Without the actual datasheets there will be a little guess work to figure a working part.
I believe Delco Remy is now just Remy. One could try and contact them for the data sheets as these parts are 32 years old, they just may give you them.
Go Marconi!
Old 09-22-2022, 07:58 PM   #12
redwire
My Country: Canada
The two-pin connector P201, schematic shows one wire is BATT, other is Park Lights. So the unit will not power up unless you have power to BATT (as well as IGN and RCVR).
The 12-pin connector also has park lights (DIM), IGN 14V, RCVR 14V (power amps) but can give no 5V power, that seems to come separately from the 2-pin connector. Very strange Delco. Maybe they wanted a quiet take off point.
On the 2-pin connector, you can put power there, not sure if orange or brown wire.
With these, NEVER connect/short a loudspeaker output to ground or you will blow the power amp IC's.
Old 09-22-2022, 10:09 PM   #13
R_J
City & State: ☻
My Country: Canada
The 2 pin cable will require +12 volts for the Batt lead as well as +12 volts to the PK Lights lead. This controls the display. the DIM connection controls the brightness of the internal (trim panel) lamps and may also control the brightness of the led display as well, so the dim also need +12 volts (or less for a dimmer display)
Old 09-23-2022, 03:04 AM   #14
toty79
My Country: Italia
Update
Thanks to the diagram I have identified R240 from 6.8 ohm (page 23 and 27) which incredibly measured 30k, replaced and now we have a clock display on (attached photo) but as you can still see the small am / fm display is off, so something is still not go, all your help is very precious and I am grateful to you
File Type: jpeg WhatsApp Image 2022-09-23 at 10.48.57.jpeg (165.4 KB, 7 views)
File Type: jpeg WhatsApp Image 2022-09-23 at 10.48.57 (1).jpeg (139.5 KB, 13 views)
Old 09-23-2022, 11:21 AM   #15
keeney123
Lauren
Quote:
Originally Posted by toty79 View Post
Update
Glad to hear that you got some of the display working. Hopefully you will find the solution to the small display.
Old 09-23-2022, 11:54 AM   #16
R_J
City & State: ☻
My Country: Canada
If the clock display is on, it could be the radio in not actually turned on. What is the voltage on the resistor R240? if it was open, something else on that line may be damaged, check if you have +5v on U204
Old 09-23-2022, 08:52 PM   #17
toty79
My Country: Italia
Hi guys ... the + 5v on U204 were present but with pulsating voltage due to a short on C231 electrolytic 16v 100uf replaced and now we also have the second display on, now that I have both displays I am dedicating myself to the amplification part, the whose audio is almost a hiss on all channels, the volume responds to the control, four IC DM113 are mounted on the amplification circuit we hope they are not fried
File Type: jpeg WhatsApp Image 2022-09-23 at 12.12.10.jpeg (238.7 KB, 6 views)
Old 09-23-2022, 10:28 PM   #18
keeney123
Lauren
You are tenacious a good trait in an electronic technician.
Old 09-24-2022, 05:51 AM   #19
toty79
My Country: Italia
Thanks keeney123 you do what you can
Changed all electrolytic capacitors on the amplifier board but still I get the same hiss, by applying an external source on connector J301 (page 7) all four channels sound perfectly, so it is excluded that it is the amplifier, but instead the noise comes from the preamplified part, the thing gets complicated and I can't understand what kind of component could affect all four channels, I would also exclude capacitors on the preampl section ... but now I find myself in a deadlock ... all the advice is well accepted ... thank you
Old 09-24-2022, 11:19 AM   #20
keeney123
Lauren
Perhaps R_J can help you with that when he gets a chance.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
