Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 09-14-2022, 07:12 PM   #1
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
Default I just bought a SkyRc MC3000 battery testing machine very interesting device temp
I just bought this device that came in the mail today I put a set of 4 brand new 21700 high current battery on the charger
The charger has four individual temperature sensors for each battery cell
The bar graph for each individual battery cell is very primitive but will give you a good idea of how each battery cell is preforming and I find something odd I put on the individual battery testing machine that gives more details of the charging/discharging curves but it will be quicker to just charge and discharge battery cells that do not have any issues
Or test battery cells that you do not know anything about this gives you a way to pre scan the battery cells to weed out batteries that have issues with out having to babysit them
The 18650 battery store where I bought the high current tool type batteries from they had a review about this battery testing machine so I decided to try it out and see if it will work better for me than the SkyRc IMAX b6 battery tester that can only do one battery at a time with the temperature sensor so this will work a lot better for me now
The SkyRc MC3000 Battery testing machine
https://www.18650batterystore.com/products/skyrc-mc3000
The 21700 batteries that I bought
https://www.18650batterystore.com/products/samsung-40t
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 09-15-2022, 02:28 AM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: I just bought a SkyRc MC3000 battery testing machine very interesting device temp
cant that charger run over bluetooth / usb to a pc or phone app with charts & stuff?
stj is offline   Reply With Quote
Old 09-15-2022, 05:16 AM   #3
sam_sam_sam
My Country: USA
Yes it can and that what I was referring to that it very primitive graphics not much details but only because of the size of temple and the way the graph is setup I used my iPad to view the graphics I will post what it looks like sometime today or tomorrow
But it does not look like you can start and stop the charger but I do not know for sure if that is the case only because I just want to see how the application was setup and if showing each battery cell temperature or not one thing that is nice about the application is that it shows you the internal resistance of each battery cell as well a very nice feature
The other SkyRc also had this feature but you had to go to another screen to see it so I did not use it very much to most of the time not at all
Old 09-15-2022, 07:38 AM   #4
sam_sam_sam
My Country: USA
With this version of there battery testing machine you set on the fly but it is not easy it is easier to create a charging/discharging profile then select the profile and you are off and running
Old 09-15-2022, 02:47 PM   #5
sam_sam_sam
My Country: USA
I have changed my mind about just how primitive this graphic application really is I was just going to storage charger them when I was watching the being of the charging cycle the charging curves were all over the place between individual battery cells so I am going to cycle them one more time and see if this situation will be better
The graduations in mil volts is what is lacking in this application but it is very useful for spotting issues with the charging/discharging cycling curves which is what I was looking for in a battery testing machine
If I want a closer look at just how bad a charging/discharging curve is then I will use the other battery testing machine for more accurate look at this situation
One note I started with storage mode was when I saw all the charging curves all over the place so I stopped the mode and when to the cycling mode
One more note the battery resistance measurement is when you first start charging mode the first time then when you do the discharge mode after that it shows N/A after this not an issue
Charge once and discharge once then when to storage mode then when to cycle mode
Overall I very impressed with this battery testing machine from SkyRc for a 4 bay battery testing machine
File Type: jpg 13873F57-6AB3-4A4A-B43E-F17751B5B694.jpg (229.4 KB, 7 views)
File Type: jpg EBDF0F0D-EEA8-4A49-AA58-7A322E9544AD.jpg (262.3 KB, 8 views)
Old 09-15-2022, 06:00 PM   #6
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Nice charger… I always wanted to get one of these…
CapLeaker is offline   Reply With Quote
Old 09-15-2022, 11:07 PM   #7
sam_sam_sam
My Country: USA
I have to figure out if it has a bug because it does not stay connected with Bluetooth for the entire charging or discharging cycle I will let you know if I figure out what is causing this issue
You can start and stop the battery testing machine remotely which is nice you can also set the temperature cutoff for all of the I have it set to 104*F / 40*C
However it does limit you one amp if you use all four bays for charging or discharging if you only one then you can do two amp maximum
Old 09-16-2022, 05:01 AM   #8
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
So that Bluetooth feature is for the app to be able to track the charging curve etc? Not sure why it wouldn’t stay connected as long as it is within Bluetooth range, but I agree with you that it very well could be a firmware problem on the charger itself.
Old 09-16-2022, 05:24 AM   #9
sam_sam_sam
My Country: USA
I might have it to far away from each other but this might be a guess but the signal strength meter shows that it is in range so this is why I am not sure exactly what the issue is but I had it running sense 2 am this morning and now it is 7:30 am and it still connected so who knows what going on with it
Apparently this application was updated became of bugs that were supposedly fixed but I know how that is
Yes this is how you see the charging/discharging curves and set the parameters for the charging discharging cycle and what type of battery cells you have are using etc
One note about the auto detection for what type of battery cell is being installed yesterday I was using it and it shows the right type of battery to start with but after a while it then it showing that it is unable to determine what type of battery cell is in that slot but this was the battery cell that had the worst charging curve after being discharged so I watching this battery cell because it was the last one to come out of pause so I might run this cell on the other battery testing machine to see what might be an issue with this battery cell
Old 09-16-2022, 10:06 PM   #10
sam_sam_sam
My Country: USA
But oddly enough all the batteries came back up and charged up correctly so I am not sure exactly what the issue was but it seems to work the way it suppose to so I do not know what happened unless it just gilded for some reason I
I going to put another set of four in the charger and let see if it has any issues doing it this time
Old 09-18-2022, 06:45 AM   #11
sam_sam_sam
My Country: USA
Well I have tested several sets of 4 batteries and so far the battery testing machine is working correctly and so I have had no issues
The batteries that I have been testing the results are very consistent with each battery cell they are within 100 milliamperes hours of each other and some of them are exactly the same amp hours which is very good I can match most of them exactly
So I have done 4 sets four of them but still have a lot to still do but will probably have all of them done before the Milwaukee battery enclosure gets here
These batteries never go beyond 90*F when charging or discharging these batteries which is very good results I have the temperature cutoff set to 104*F and the charging rate set to one amp the discharge rate is set to one amp as well I cycle them once
One note about the temperature sensor and where it is located will work for batteries up to 21700 but for batteries sizes bigger than this I would have to use the other SkyRc battery testing machine for battery temperature testing issues but not a deal because I do not test a lot of batteries sizes bigger than 21700 anyway
This SkyRc MC3000 is priced at around $100.00 depending where you buy it from to me it is worth it however I think it falls short of being a extremely good value for the money in one aspect and it is that the application could be better designed and easier to use but this is true about there other battery testing machine that I have and it has the same issue with the application it is some what primitive in nature this true about the graphics could be a lot better and easier to read for plotting purposes but like I mentioned earlier because I have a better battery testing machine for the graphics but it also falls short but it is that the charging controller section of it some short flaws when you try to charge battery packs with BMS balancing protection board it really can not do them correctly depending on the BMS protection board
On this note remember that I was talking about some battery packs that I was having issues with charging them well turns out that the BMS protection board has issues with charging portions of the circuit so I just going to reuse the batteries and scrape the BMS protection boards that do not work correctly anymore I think that why they were recycled to Battery Hookup for resale
File Type: jpeg 4A812245-9EDD-460E-A332-428D7D08A5E3.jpeg (669.5 KB, 3 views)
Old 09-18-2022, 08:49 AM   #12
sam_sam_sam
My Country: USA
One note about the issue with the charging controller for the EBC-A10H is would have been better to have slowly ramp up the charging current to the setup set point instead of insatiately going to the set point then you might have been able to charge battery packs that have BMS protection boards on them
Old 09-22-2022, 09:19 PM   #13
sam_sam_sam
My Country: USA
One note about this SkyRc battery testing machine I found out that you have to power cycle the tester after each use so that it will reconnect with the Bluetooth function it is kind-a anointing that you have to do this but it must be some type of bug issue that might be addressed in firmware update
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
