Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Appliances and other Household Electronic Stuff
Thread Tools Display Modes
Old 08-26-2022, 09:25 PM   #1
steves7839
City & State: Atlanta Area, GA
My Country: USA
Line Voltage: 120VAC 60HZ
I'm a: Knowledge Seeker
Default Blomberg electric dryer - Need a replacement relay
A neighbors Blomberg electric dryer has been tumbling OK but refused to heat. The heater coil and sensors test OK.
The control board relays are pictured. Only one of the four cannot be activated with current to the relay coil terminals from a 9V battery.
What brand/manufacturer is this relay? I've tried searching the numbers on the Digikey website to no avail.
steves7839 is offline   Reply With Quote
Old 08-26-2022, 11:35 PM   #2
redwire
City & State: Alberta
My Country: Canada
Default Re: Need a replacement relay
It's a cube relay rated resistive load 10A 125/277VAC, 12VDC coil.
Panasonic JS1a-B-12V-FT but obsolete now.
Consider Omron G5LE-1A-DC12 or the high capacity or sealed versions would work as well. Note there is a safety spec on the original relay for "Flame resistance and tracking resistance meet EN60335-1" as the "T" option that I don't specifically see for the Omron.
redwire is offline   Reply With Quote
Old 08-27-2022, 05:20 AM   #3
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
10A @120v is only about 1.2KW
is the relay overloaded or does the dryer have a crap heater?
in europe our dryers are 2KW+, at 120v that would be 16A
stj is online now   Reply With Quote
Old 08-27-2022, 10:05 AM   #4
steves7839
My Country: USA
Thank you for that ID!
The heater coils are rated 600W and 1400W and can be run separately or simultaneously, thus separate relays. To my surprise, the stuck relay powers the lower-wattage coil.
Old 08-27-2022, 10:18 AM   #5
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
USA dryers are also 2KW+, but usually run across both phases for 240V so we don't have 16A circuits...
eccerr0r is offline   Reply With Quote
Old 08-27-2022, 12:01 PM   #6
petehall347
City & State: worcester
My Country: United Kingdom
did you test it in circuit ? if so the flyback diode might be shorted or you connected battery wrong way .
petehall347 is online now   Reply With Quote
Old 08-27-2022, 12:51 PM   #7
redwire
My Country: Canada
Blomberg don't seem to offer any service manuals, I kinda regret buying their dishwasher now
Appliance control board relays fail mostly due to contact arcing - manufacturers refuse to add a RC snubber or MOV to mitigate this and give longer life. Load current doesn't matter much - any heater, motor, solenoid etc. can generate contact arcing. The relays can also fail due to contact heat as the contacts wear- they can melt their housing.
There have been many appliance board fires/recalls due to cracked/bad solder joints on the PC boards as well, always do a visual and touch ups with the soldering iron.
The JS 12V coil pull-in minimum is around 8.4V/30mA so a 9V battery should do it, unless the surrounding circuitry is in the way or polarity is wrong. A "click" doesn't always say much, as far as bad contacts. The real test is to pull a relay off the board and use a bench power supply to move the coil, as well as pass good current through the contacts like a car tail light bulb load. An ohmmeter reading is no good across closed-contacts due to oxides, carbon etc. giving what look like good readings that fizzle out under load. You have to run at least an 0.5-1amp through the contacts to test them.
Another option is Songle SRD-12VDC-SL-C cheap and easy to find, or Song Chuan 215H-1AH-F-C-12VDC {Mouser}. Although the Japanese brands are best quality, only Omron seems to still be making these size sugar cube relays.
Old 08-27-2022, 07:42 PM   #8
steves7839
My Country: USA
Quote:
Originally Posted by redwire View Post
Consider Omron G5LE-1A-DC12.
Looks the same. I just ordered three from Digikey. Thanks!
Old 09-06-2022, 07:58 PM   #9
steves7839
My Country: USA
I replaced both relays that power the heater coils. Perfect fit. To my surprise nothing changed on the control board. The R5 relay would not switch when activating the coil terminals with 9Vdc through a resistor. I also found (or melted) and replaced the diode that shorted when I tried to activate the R5 coil.
Tomorrow, I plan to test the reworked control board in the dryer but am not optimistic.
Does anyone know of a schematic for a Blomberg control board?
Old 09-09-2022, 05:30 PM   #10
redwire
My Country: Canada
Default Re: Blomberg electric dryer - Need a replacement relay
I guess no Blomberg appliance service manuals exist on the Internet
If you provide clear pictures of the board (both sides) we can figure out a few things.
There can be a safety-interlock, such as a door switch, fan airflow, overtemp etc. that could be in the way preventing the heater relay from engaging in the first place. A few (front loading) appliances have kooky door locks as well, using a PTC heater/latch, because children apparently climb in there for a wash or dry.
Old 09-10-2022, 04:52 PM   #11
steves7839
My Country: USA
I ordered a replacement control board. My primary concern is whether the moisture sensor could be open. It consists of two metal plates fixed inside the drum. Naturally it ohms in megohms from the control board connection. But the transformer that “senses” changes in moisture level also reads very high ohms. I suspected a dry reading might cause the heater to disable. So I added wet laundry but it made no difference.
Any technique for testing or bypassing that moisture sense circuit?
Old 09-10-2022, 11:31 PM   #12
redwire
My Country: Canada
We don't have a model number, no pictures- you're making this too difficult to help.
The "humidity sensor" is two metal electrodes that conductivity is monitored. If moist clothes touch the sensors, it registers a blip as "still wet".
The electrodes can get a buildup of fabric softener wax or mineral deposits on them which would give high resistance (=dry clothes). Even if the humidity sensor wrongly reads dry, it should run for minimum of a couple minutes before shutting off.
You could spoof wet clothes with maybe a 1MEG resistor or wet noodle across the electrodes. I don't know what "transformer" you are talking about, they don't use that for a moisture sensor.
Old 09-11-2022, 01:20 PM   #13
steves7839
My Country: USA
Not intentionally, but here is the fix. Model is Blomberg DV16540. I'm posting pics of the schematic included with the dryer, and the main board. Very little detail of the main board circuitry was provided.
The connection to the moisture sensor plates is at the upper right of the main board, labelled KN5 on the schematic but screen printed KN1 on the main board.
Old 09-11-2022, 02:53 PM   #14
stj
stj's Avatar
check the drive transistor for the relay coil
Old 09-11-2022, 06:19 PM   #15
redwire
My Country: Canada
RLY5 driver transistor Q32 would be the same type as Q31. I can't see if the Q32 base leading from R109 goes to Q31 or anything (some safety interlocks etc) other than right to the MCU, pic is too blurry to follow the relay power as well.
For functional safety, there can be a master power switch (transistor) for the heater relay coil power, as well as the individual on/off transistor for each heater.
Back-EMF diode D26 is missing, MELF package like LL4148 or LL/DL4002 etc. It would get blown if the 9V battery was connected backwards I think. You still need a diode there.
A q-tip and IPA can clean off the extra flux.
Old 09-11-2022, 06:38 PM   #16
ajshoe
ajshoe
City & State: cincinnati, ohio 45215
My Country: usa
your swaping parts without testing. first thing I would do is monitor voltage out of heat relays. turn on dryer with heat. If your getting voltage (110V for each relay - has 2 elements so the control bd controls the amount of heat in the drum) - problem is down the line - sensors, wiring, heater. if not - next take out relays and bench test them. If relays all test good and no voltage -- test caps on control board for proper ESR. not a good idea testing relays in circuit board. I repair these boards occasionally - unfortunately some dryer boards have a proprietary chip on them that sometimes is the cause of failure (whirlpool is famous for this). doesn't look like this one does. worked on a lot of dryers but never seen a blomberg !
ajshoe is offline   Reply With Quote
Old 09-11-2022, 10:15 PM   #17
steves7839
My Country: USA
Q32 and Q31 do not appear to be interconnected. With a multimeter in ohms and diode check modes they appear to be normal and resemble the drivers of the motor relay coils.
I installed a larger diode for D26, a 1N4004, after this pic was taken. Yes, I must have forward biased D26, since the solder melted.
Old 09-13-2022, 07:22 PM   #18
redwire
My Country: Canada
If the heater relay transistors are independent, then it's either the switch circuit for the relay coil or the MCU is refusing to turn on high heat.
Have you checked the heater temp sensor? 19.5kΩ at 25°C. To see if the board thinks the heater temperature doesn't warrant high heat on.
(same as the door NTC apparently but I think it gets heated to lock).
Old 09-15-2022, 06:55 PM   #19
steves7839
My Country: USA
I did measure resistance of both temp sensors as seen by the control board. As expected both were about 17-18kohms at ambient and varied in response to touch with a warm finger.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
