Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Old 04-19-2022, 10:40 PM   #1
kingskie
City & State: tangerang
My Country: indonesia
Default 820-01521 only shows 5V 0.04A
i've been working on macbook air 820-01521
it is dead no charging. tried to connect to apple configurator always shows accessories not supported.
using amp meter only shows 5V and 0.04A
here are some measurements:
PPBUS_G3H = 12.26V
PP3V3_G3H = 3.275V
PP5V_G3S = 0V
PP20V_USBC_XA_VBUS = 5V (can i inject 20V 1A here?)
kingskie is offline   Reply With Quote
Old 04-20-2022, 03:11 AM   #2
reassor
City & State: Tychy
My Country: Poland
Default Re: 820-01521 only shows 5V 0.04A
First check why there is no 20v.
Check CD chips.
Most of the time if you manage to make them go board will wake up.
Do not start from back
PP5VG3S_EN present?
How do you have 12.2v on main rail?
Do you meassure with battery connected? (come on)
reassor is offline   Reply With Quote
Old 04-20-2022, 09:03 AM   #3
mon2
mon2's Avatar
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
No!! If you are not getting to 20v, something is wrong.
Remove all power. Meter in diode mode.
Red lead - yes RED meter lead to ground.
Black meter lead to a LDO rail of each ACE power delivery controller.
Check the LDO rails in diode mode of each ACE controller and post the readings.
Repeat for each ACE device.
mon2 is offline   Reply With Quote
Old 04-22-2022, 09:54 PM   #4
kingskie
Check CD chips.
PP5VG3S_EN present?
there is no rail called PP5VG3S_EN
yes i have 12.26V on PPBUS rail
Old 04-22-2022, 10:00 PM   #5
kingskie
PP3V3_UPC_XA_LDO = 26K ohm
PP3V3_UPC_XB_LDO = 25K ohm
PP5V_S5_LDO = 15.4K ohm
Old 04-23-2022, 06:55 AM   #6
mon2
mon2's Avatar
My Country: Canada
These are resistance readings. Do you have a diode scale on your meter? Can you post a pic of your meter?
Then review my earlier post on how to use the diode mode scale and take the measurements.
Old 04-24-2022, 11:15 PM   #7
kingskie
i'm using fluke 101
Old 04-25-2022, 06:34 AM   #8
inflex
City & State: Townsville, QLD
My Country: Australia
Originally Posted by kingskie View Post
i'm using fluke 101
Press the yellow button to cycle through to diode-mode.
It'll likely show a diode symbol on the screen
YouTube Repair Videos - https://www.youtube.com/user/19PLD73
FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
inflex is offline   Reply With Quote
Old 04-25-2022, 03:37 PM   #9
Simplebeans
Simplebeans's Avatar
City & State: Leicester
My Country: UK
As mon2 said kingskie, checking diode mode readings should start to give you a idea of which ACE controller may be acting differently. It may show all the same readings for all but it is a good place to start to see any differences.
Simplebeans is offline   Reply With Quote
Old 04-26-2022, 03:49 AM   #10
kingskie
U3200
PP3V3_G3H_RTC = 0.425
PP3V3_UPC_XB_LDO = 0.466
PP1V8_UPC_LDOA = 0.482
UPC_XB_R_OSC = 0.481
UPC_XA_UART_TX = 0.682
PP1V1_UPC_XB_LDO_BMC = 0.460
UPC_XB_GPIO1 = 0.705
PP1V8_SLPS2R = 0.327
PP1V8_UPC_XB_LDOD = 0.444
UPC_XB_SPI_CS_L = 0.536
UPC_XB_SPI_CLK = 0.519
UPC_XB_SPI_MOSI = 0.541
UPC_XB_SPI_MISO = 0.537
I2C_UPC_XB_DBG_CTL_SCL = 0.716
I2C_UPC_XB_DBG_CTL_SDA = 0.715
PHV_INT_XB_G3H = 0.589
UPC_XB_GATE2 = 0.595
PPDCIN_G3H = 0.519
PP5V_G3S = 0.393
TBT_POC_RESET = 0.514
USB_X_RESET_L = 0.707
TBT_X_USB_PWR_EN = 0.492
PP20V_USBC_XB_VBUS = 0.108
USBC_XB_CC2 = 0.550
USBC_XB_CC2 = 0.533
USBC_XB_SBU2 = 0L
PD_TBT_XB_LSRX = 0.692
PD_TBT_XB_LSTX = 0.759
USB_UPOC_XB_F_P = 0.580
U3100
PP1V8_UPC_XA_LDOD = 0.448
PP1V1_UPC_XA_LDO_BMC = 0.461
PP3V3_UPC_XA_LDO = 0.468
PP1V8_UPC_XA_LDOA = 0.482
The lowest is PP20V_USBC_XB_VBUS and USBC_XB_SBU2 is 0L
Old 04-26-2022, 05:15 AM   #11
mon2
mon2's Avatar
My Country: Canada
Do you see the same voltage and current draw for each USB type C port?
What are the voltage readings of the following?
PP1V8_SLPS2R
PP1V1_SLPS2R
Old 04-26-2022, 11:13 PM   #12
kingskie
do you see the same voltage and current draw for each usb type c port?
pp1v8_slps2r
pp1v1_slps2r
pp1v8_slps2r = 1.793v
pp1v1_slps2r = 1.096v
Old 04-27-2022, 05:08 AM   #13
mon2
mon2's Avatar
My Country: Canada
These 2 rails are ok. They power the T2 device.
Old 04-27-2022, 09:27 PM   #14
kingskie
yes they both have the same current draw...could it be T2 chip is the culprit or PMIC?
Old 05-09-2022, 04:36 AM   #15
kingskie
any suggestions?
Old 05-09-2022, 04:59 AM   #16
mon2
mon2's Avatar
My Country: Canada
SBC_XB_SBU2 = 0L
Is not correct for this diode reading. Can you check again?
It should be about 0.65.
Check also
USBC_XB_SBU1
USBC_XA_SBU1
USBC_XA_SBU2
Old 05-09-2022, 10:21 PM   #17
kingskie
SBC_XB_SBU2 = 0L
Check also
USBC_XB_SBU1
USBC_XA_SBU1
USBC_XA_SBU2
i checked USBC_XB_SBU2 from the test point that i attached still OL
USBC_XB_SBU1 = OL
USBC_XA_SBU1 = OL
USBC_XA_SBU2 = OL
File Type: jpg Screen Shot 2022-05-10 at 11.15.10.jpg (341.0 KB, 6 views)
Old 05-10-2022, 02:54 AM   #18
mon2
mon2's Avatar
My Country: Canada
Post a pic of your multimeter so we can confirm the diode mode setting.
Old 05-10-2022, 03:00 AM   #19
kingskie
this is my multimeter
Old 05-10-2022, 03:52 AM   #20
mon2
mon2's Avatar
My Country: Canada
You are in ohms mode.
Press the yellow button till you see the diode symbol and measure again.
