Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Thread Tools Display Modes
Old 05-09-2022, 02:22 AM   #21
kingskie
City & State: tangerang
My Country: indonesia
I'm a: Knowledge Seeker
Default Re: macbook pro 820-00840 have image no backlight
Quote:
Originally Posted by mon2 View Post
Refresh the list of voltage measurements
Voltage after fuse ?
Voltage before current sense resistor.
Voltage after current sense resistor.
Gate voltage of mosfet.
Voltage on drain of mosfet.
And so on..
voltage after fuse 13V
voltage before current sense resistor 5V
voltage after current sense resistor 5V
Q8401
pin 1-3 = 0.056V
pin 4 = 0V
pin 5 = 0.009V
kingskie is offline   Reply With Quote
Old 05-09-2022, 03:06 AM   #22
mon2
mon2's Avatar
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
This is not correct. Please check again.
If still the same measurement then remove all power.
Check the resistance between the fuse and the current sense resistor.
It should be ~ 0 ohms.
There is something incorrect here. The voltage after the fuse must travel into and exit the current sense resistor.
Update..
What are the full markings of the chip you are replacing at u8400 ?
mon2 is offline   Reply With Quote
Old 05-09-2022, 04:33 AM   #23
kingskie
Update..
sorry my mistake. i measured wrong current sense resistor.
the current sense resistor is R8400 right?
the resistance between the fuse and the current sense resistor is 0.5 ohm
the voltage at the end of current sense resistor is 13V
hereby i attached the U8400 that i took from A1502
Old 05-09-2022, 05:11 AM   #24
mon2
mon2's Avatar
My Country: Canada
Is this a pic of the donor board or the board you are are repairing ?
Old 05-09-2022, 08:30 AM   #25
kingskie
this is the pic of the board that i am working on. 820-0040
Old 05-10-2022, 09:44 PM   #26
kingskie
U8400 i took from 820-4924-A
Old 05-10-2022, 10:02 PM   #27
mon2
mon2's Avatar
My Country: Canada
Use the boardview file to confirm that no parts are missing around this backlight IC:
https://www.badcaps.net/forum/showthread.php?t=69489
See some blank pads in the pic. Also no solder shorts.
Have not had enough quality time to review the same.
Old 05-10-2022, 10:17 PM   #28
kingskie
yes @mon2 all the parts are there. the bank pads is no stuff in the schematic.
Old 05-12-2022, 08:59 PM   #29
kingskie
any suggestions?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
