Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Other Devices with Bad Capacitors
Old 09-28-2019, 05:04 PM   #1
ageman
City & State: bridgwater. united kingdom
My Country: united kingdom
Line Voltage: 230VAC 50Hz
Default Transistor identification
Hi I am looking for some help trying to identify an NPN transistor. It is marked TCDL 83-92. Please see attached photo. Any help would be appreciated
ageman is offline   Reply With Quote
Old 09-28-2019, 06:57 PM   #2
petehall347
City & State: worcester
My Country: United Kingdom
Default Re: Transistor identification
maybe in house number .can you find a parts list for the unit ?
Old 09-29-2019, 02:53 PM   #3
ageman
Hi Petehall
no cannot find any information on the unit
Old 09-29-2019, 04:26 PM   #4
petehall347
what is the unit ? are there anymore transistors same number ? if so you could at least work out the pin out .
Old 09-29-2019, 09:17 PM   #5
ageman
Hi pete hall. It is a led ballast unit for an emergency light. There is another transistor marked the same the pin out is as follows:1
pin No
1 Emitter
2 Collector
3 base
Old 09-30-2019, 03:03 AM   #6
stj
stj's Avatar
City & State: Europe
do you have a component tester?
Old 09-30-2019, 09:40 AM   #7
ageman
Yes I have component tester. Details on the attached photo
Cheers Adrian
Old 10-01-2019, 04:09 AM   #8
stj
stj's Avatar
so does the board contain anymore of those transistors - ones that work?
Old 10-04-2019, 01:36 AM   #9
ageman
Hi
yes this is the one that is shown on the component tester
Regards
Adrian
Old 10-04-2019, 03:49 AM   #10
stj
stj's Avatar
well if you know the spec, what's the problem?
or just stick an NPN ZTX seies in there - thoes can handle serious power.
Old 10-04-2019, 04:04 AM   #11
ageman
I was struggling to find something similar to replace it with.
Regards
Adrian
Old 10-04-2019, 05:11 PM   #12
stj
stj's Avatar
any idea on the kind of voltage it has to handle?
maybe a ztx450 would work - but you need to bend the leads a bit.
Badcaps.net Technical Forums © 2003 - 2019
