The Fan seems to work fine with the extra capacitor in parallel with the old one, so if the capacitors I linked to in a previous post are OK I'll order those.
Yes it should be fine, probably does not matter if it is low ESR or not in this circuit.
It might be a good idea to check the capacitance of the C1 X2 film capacitor as well, if you are anyway placing an order...
4 years on this discussion helped me repair my fan, same 449252 pcb, labelled as type F100T1 Lieferant supplied by APL, probably from Toolstation, about 8 years old. Same fault with underspec electrolytic 220 uf capacitor, replaced and working again. Thanks.
