This came off while desoldering, my mistake How can I fix this?? I tried putting it back on and soldering but it was too damaged
What to do about missing pad on lead?
Re: What to do about missing pad on lead?
What is the component - doesnt look like the pad was connected - may just be a blank pin- did you take any pictures before you started.Please upload pictures using attachment function when ask for help on the repair
Zoom out slightly so we can see where the trace is going. Also show the topside so we have an idea.--- begin sig file ---
--- end sig file ---
What board is this?--- begin sig file ---
I cant see a trace from where the pad was - that is why I thought it was just a blank pad - unless there is a trace on the otherside or it is a multilevel board.Please upload pictures using attachment function when ask for help on the repair
If this is a 2 layer board the trace will be on the other side just solder the component from the top and you'll be fine.
If it's a multilayer board and there is no trace on the top you're out of luck.Elements of the past and the future combining to make something not quite as good as either.
I'd be willing to guess that this is OK, and this pin doesn't go anywhere on the other side (if this was a through-plated via hole) ... that is, if this is even more than single sided as most PSUs are 1-layer... Is there a wire connected on the other side of the board on that hole?
You might lose a bit of durability as even if it wasn't connected to anything, it does hold the part on the board... but you probably could have told that the others do much more than enough to make sure the transformer doesn't fall off
How you doing with the 740NPlease upload pictures using attachment function when ask for help on the repair
Originally posted by Pentium4 View PostIt's a PowerMan PSU, here are the pics! Yeah it doesn't look like it goes anywhere but I want to make sure!!! Looking at the second picture it is the 3rd pin from the left
Single layer board, with no trace leading to the pad hence it serves no purpose.
More than likely there because the winding core had it already or for ease of alignment during manufacture.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yes, well you will need to tell us what you were doing to it and why.
Bigger pictures of the whole thing not just parts. What was it connected to?Please upload pictures using attachment function when ask for help on the repair
Originally posted by selldoor View PostYes, well you will need to tell us what you were doing to it and why.
Was it working before you upgraded the transformer?Please upload pictures using attachment function when ask for help on the repair
