I just bought a bundle with a Abit BX133-RAID, a 866MHz P3 (SL4CB) and a 256MB PC133 SDRAM stick, that the seller claims were working fine together.
After building a rig out of it, with a known working PSU (Seasonic S12II 520W, for its good 3.3V and 5V rails), I get a good startup screen, but as soon as I try to enter the BIOS, it locks up with a blue bar across the bottom of the screen.
I have seen one thread from 2010 about this issue specifically on Vogons, and the consensus there was that bad caps may very well have something to do with it, and although I can't see any visual damage or bulging (maybe ever so slight on two of the 25+ caps), Jackcon from around the year 2000 isn't exactly promising. Every cap on the board is from them, their "B058 Low E.S.R." series, apparently
From what I can tell, the board has, more specifically:
11x 6.3V 1500uF 8x17mm* - Just above the CPU socket
4x 6.3V 1000uF 8x15mm* - Between the CPU and the AGP port
7x 10V 1000uF 8x15mm* - Surrounding the CPU socket and chipset, between it and AGP/DIMM/USB ports
7x 16V 100uF 6x10mm* - Spread out, between PCI slots, between ATX power and DIMM sockets, close to CMOS batt,
1x 25V 10uF miniscule :p - Next to Super I/O chip
* I don't have a super accurate way of measuring them on the board.
Any suggestion for suitable replacements? Panasonic FR's are probably the easiest to get a hold of here (through ELFA Sweden), but I'd be very grateful for any input!
Thanks a lot in advance!
/Chris
/Chris
