The other advantage of an SSD is that they are not prone to mechanical failures, as there are no moving parts, so IMO, they are more reliable than a HDD (especially considering how unreliable all HDD manufacturers are nowadays)
partially true. They will eventually slow down and die. Depends on how often its used and how much its used
edit: my box takes 10 seconds to boot too, but I have 2 WD Velociraptors in raid 1
Not that long ago, I thought pretty much the same thing. That being, too much money, not enough space. That was until I figured out how they're supposed to be used.
The idea is to load your programs and operating system on the SSD, then get a large slow mechanical hard drive for storage. It's not meant to replace a mechanical hard drive, it's meant to augment a mechanical hard drive. The specific purpose is to speed up your operating system and programs.
You're not buying space, you're buying speed.
A man convinced against his will is of the same opinion still.
I'll take the slightly lower speeds but the reliability bonuses + RAID abilities with my old spinners... Not quite ready to jump on the SSD bandwagon yet. A few more years of seasoning, they will be ready.
^and I bet it uses a lot of power and is slow (for an SSD too... you get what you pay for sometimes.
Well I don't know about that. I stated what the speeds were with my 120GB version of that drive in my SSD thread. I'd hardly call that slow. Are there faster ones? Yes. But that last few percentage points just don't make sense when you figure in the cost difference.
Edit: From what I read, with SSD's, usually the larger drives are faster than the smaller ones, in the same brand / product line anyway.
Now... 48x SSDs in RAID 0 would be epic paired with dual 8-core Intel Xeons, 32GB of RAM, and an additional 48x WD Raptors in RAID 0 (for storage, the SSDs would be for OS/games)...
Anybody got a few million bucks to waste to try that?
Even more awesome was that they were only to get over 2GB per second with 10 or 16 ssd drives out of 24.
The hardware raid intel controller on the 24 port areca card was just not powerful enough to route the data to all 24 sata ports and keep the transfer speed high.
Those SSD drives had something like 150 MB/s max read speed - nowadays you get to 260-450 MB/s with each one.
Why would you install games on C: ? C: is traditionally for operating system, not movies and games.
Went through this with another guy on Jonnyguru's forums...
You don't have to keep Steam on C:, it works just fine from any other partition. Mine is on K:
Just copy folder, edit 2-5 registry keys (change paths to point to new folder), reboot.
You install games on C: if C: is your fastest drive, and you want to wait the least amount of time at the loading screens. Any game with an open world will be loading off the drive constantly as you move (even with 8gb of RAM). A slow drive leads to stuttering during gameplay.
