Re: HP W2408 Problem
Bingo!!!! We are getting closer to the fault. The SMPS controller begins operation when that pin rises to 16 volts and ceases operation when it drops below 10 volts. During normal operation it should be at 20 volts. There are several possible causes, but the first suspect is the 'startup cap'. The most likely component for that is C872. I'd suggest checking the voltage across it. If it has the same behavior as pins 10-15, replace it.
PlainBill
Originally posted by brunolundh
View Post
PlainBill
