Hi I have a motherboard which is untested however I can see it has one visibly bad cap. It is 6.3 V, 3300 uF, and the temp is rated at 105 C.
I have a spare cap laying arround that is the exact same physical size, and has mostly the same specs. The only difference is the spare one is only rated at a temp of 85 C, not 105.
I understand that installing this one is not a good long term solution, however if I install it will it work for even a small amount of time? I just want to test the motherboard. If I install it and the motherboard works I will remove it and order the cap that is rated for a higher temp. So can I use this one for now as a test? Or would I risk further damage by installing it?
