What fast food does to electronics
    As some of you may know, I work at a burger king. Today one of our credit card machines went down as the power supply sat in a puddle of water on the ground for an extended period of time and stopped working. We replaced it with a unused power supply from an unused credit card machine and everything worked fine. I took home this power supply to see if I could get it working again, and this is the horror I was confronted with when opening it:
    Holy.
    Butt.
    Nuggets.
    I sprayed down the PCB front and back with Simple Green and soaked the case in vinegar and wire wheeled the corrosion off of anywhere that had it, and it starts up now.
    Re: What fast food does to electronics
    yuck! that looks disgusting
      WTF! I'm showing this to my sis, brb.
      Edit: She compared this to a simulation of what happens to your arteries.
      Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
      I have two v2s and one v1.
      I am still looking at these boards nearly every day.
      What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
        Most of it looks like mineral deposits from hard water or water with chemicals (cleaners) in it.
        If the casing is aluminum it might be aluminum oxide.
        Mann-Made Global Warming.
        - Dr Seuss
          Yeah it's all just corrosion. The brown stuff is the aluminum corrosion mixing with the rust from that little bolt that holds a diode to one of the heatsinks. I just thought it was funny that this came out of a burger king. Kind of impossible for it to get grease in it, as it sits on the other side of a huge stainless steel wall that keeps the fryers out of view.
            I'm always amazed at how far devices can be away from the kitchen and they still fill up with greasy dust. It's in the air.
            Supersize me!
            sig files are for morons
              Looks like sour cream and cheese! Eww!
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              16 GB AData XPG Spectrix D41
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
                One person at work used to service equipment for fast food places, and some french fry machine controllers had an internal setting to select one of ten different songs (he'd clean out the grease and reset all of them to "Yellow Rose of Texas"), and the power supply was double isolated, with one 60 Hz stepdown transformer feeding another 60 Hz stepdown transformer. He said McDonald's had their equipment sent to a Panasonic facility in Illinois that also fixed monitors. I had one of those refurbished monitors, and I hope Panasonic was more careful with the McDonald's equipment.
                  I would consider this unit a write-off.
