I'm trying to repair a Dell 2208WFP LCD monitor. The backlight goes out after turning it on for a couple of seconds. I managed to disassemble it and identified some bulging capacitors on the power board.
However, since this was my first time disassembling a LCD monitor, I accidently pulled one of the ribbon cables out too hard and broke a plastic connector tab holding it in.
Specifically, this is the small ribbon cable that connects to the front bezel menu buttons. The connector tab I broke is colored brown, and seems to hold the ribbon cable in by only friction. Should have probably pushed instead of pulled. Anyway, no amount of glue will help, as the connector tab is small and hopelessly shattered to pieces.
But, I think if I found a replacement, I could snap it back into its holder, and everything would be ok again. I don't suppose any stores would sell this kind of connector separately? It seems to be a common part among all types of LCD monitors, but I don't know how common.
If I can't find it separately, then what is the smallest and cheapest part I can buy that includes it?
btw, the connector is labeled P305 on the PCB board. The white housing is ok. Just the moveable tab part was broken.
Forget to ask, does this connector have a name? It takes 8 leads or pins.
