HP elitebook 8570p dump
    need bios
    Re: HP elitebook 8570p dump
    send board mobo number maybe some help.
      plz need bios urgently
        try this and reply.
          thanks you very much but now i cant check laptop already take back by customer
            elitebook 8570p Bios need
            hi guys
            i need a bios of hp laptop elitebook 8570p core I5
              Re: elitebook 8570p Bios need
              Your machine what problem?
                turn on but no diplay
                  Originally posted by nicoleluca300 View Post
                  hi guys
                  try this/
                  https://www.badcaps.net/forum/showpo...43&postcount=7
                    Thanks you very much long time I was looking for dump BIOS to the Elitebook 8570p and we did it Confirmed the files correctly work ( to the write your dump I used MiniPro and work well and I`m happy because i can used my laptop without password to the BIOS. Thanks again
                        thanks for uploading
                            thank you very much
                              Originally posted by imranromi View Post
                              try this and reply.
                              Bro, I have the same problem with my HP Elitebook 8570p. It has got an admin password. I can't go into bios settings and can't change anything. How can I use this dump file? Thank you very much for all your help.
                                you need a software programmer (ch341a, TL866A) ... remove the bios chip from the motherboard, make a copy, write the chip with the new bios, soldering the bios chip ... more information you can find on the internet ...
                                  Why can't we do the reprogramming without removing the chip from the motherboard? There must be an easier way to do this.
                                    If you think there is another way, let us know what it is.
                                    If you want use SOIC clip, but best way is to program the chip out of the circuit. Desoldering the chip from the board is easy job, what would be the problem?
                                    Become a Badcaps supporter
                                    Thanks to all supporters.​
                                      Using soic clip is an easier method. But if you mean a software method then no, don't get that comfortable Passwords are there for a reason and they shouldn't be TOO easy to bypass.
                                        Originally posted by RethoricalCheese View Post
                                        ...don't get that comfortable ...
