I have been going through my power supplies to see if they have problems since I have seen what happens if you wait until something pops. I remembered this Ultra 550 (ULT-X2550P) supply that I had in an old case. I pulled it out and found a main cap bloated. I also found the strangest arrangement of capacitors. You have to look at the pictures but they stacked two caps in the same space. The top cap has heatshrink on the legs of the cap.
I have already replaced ALL the capacitors and it all seems to work, the voltage is within ATX specifications but on the high side. The main chip is a KA7500 if that matters. Does anyone know if this can be adjusted and how to go about it? Also I would like to do the 5VSB OVP mod to this supply if it is applicable, can anyone tell me if this is the type of supply that needs this done?
12V = 12.01V
5V = 5.19V
3.3V = 3.39V
I really like this supply, so any input on improving it would be appreciated. I have already added a resistor across the thermosistor to increase the fan speed.
Thanks for your time,
Lloyd
12V = 12.01V
5V = 5.19V
3.3V = 3.39V
Lloyd
