Re: Sony KDL-55EX620, no stand-by volts from one bad resistor?
When the conditions of ac detect of ic6501 are met pin 26 logic is HIGH. Since VCC of that ic is ~18 volts I would believe +18 on pin 26 would be considered HIGH,
PH6302 (led) is off, transistor between 3 & 4 open, Q6402 off (open) +3.3 applied through R6403 and R6404 to AC_DET_OFF = 3.3 volts.
If you are getting 0 volts on AC_DET_OFF, Q6402 could be shorted.
